Does not get eliminate nedle noise - Audio Players & Recorders
More information needed
Posted on Aug 15, 2008
SOURCE:
How to eliminate the static in reception? When I touch or hold antenna it's clear; but can't do that all day!
Is the static there all the time.. I.e noise from external source such as a motor or possibly LED lighting.
It's better to eliminate the noise at source. Try turning power off one breaker at a time.
Another option is to run the radio on a battery to see if the noise is mains related.
Aug 13, 2015 | Radio Communications
Sometimes wen I try to start it . I turn petrol on I kick it over 3or4 times petrol fluds out of the bottom of carb
Hi mark the float nedle valve is sticking or worn out remove carb and clean it if that don't work replace the nedle valve. Regards Jim...
May 15, 2015 | Motorcycles
How to eliminate hum noise on Peavey XR122D 1200 watt powered mixer
Sounds like a ground loop. Is the noise present with NO inputs?? Or?
Jul 21, 2014 | Peavey Audio Players & Recorders
2007 Kawasaki Eliminator 125 top end noise
Hi, Anonymous I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH---WHINE
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK& RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.kawasakimotorcycle.org/forum/mechanics-corner/74033-eliminator-125-engine-noise.html
https://community.spiceworks.com/topic/99321-motorbike-engine-ticking-noise
Kawasaki Eliminator 125 Service Manual
OEM Parts for Kawasaki
2007 Kawasaki Eliminator 125 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 10, 2014 | 2007 kawasaki Eliminator 125
2007 Kawasaki Eliminator 125 engine noise
Hi, Rafael I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
2. Belts---CHIRP
6. Cylinders---PING
8. Fenders---SCRAPE
11. Gears---WHINE
16. Pistons---SLAP
Jun 14, 2013 | 2007 kawasaki Eliminator 125
2c engine chucking noise like its out of timing.
When the fault diagnosis for engine noise is too big, should first eliminate noise caused by the attachment, such as produced by air compressor and the power device, don't put these mistaken for the noise of the engine noise. Remove the accessory drive belt to eliminate noise caused by these devices. Noise will spread to those who have no problem on metal parts. So use the stethoscope will help determine the position of the engine noise.help you diagnostic tool
Mar 15, 2013 | Cars & Trucks
I have 2 pipes one is at the back of the tank its pouring petrol out i thought it was just a breather
More likely a carb overflow pipe. (You should be able to track the pipe back to a carb to confirm this guess. If I'm right, you probably have a problem with the nedle valve in a carb sticking.
I would suggest: Remove carb, remove float chamber, take the pin out of the float himge, remove nedle valve, wash all in clean fuel, blow dry, reassemble.
Jun 30, 2011 | 1989 Yamaha TZR 250
How can I eliminate handling noise from my AMT Wi5C ?
I am not familiar with this model. But for most condenser mic, you should use shock mount to remove such unwanted noise. Hope this helps
Mar 12, 2010 | Audio Players & Recorders
2005 Sonata - Speakers keep cutting out
your speakers are all blown or water damaged
Aug 18, 2009 | 2005 Hyundai Sonata
TS-450S Noise Blanker, No 1 & No 2 neither has any effect on noise
The noise blanker settings on the TS-450S (and S/AT) are true noise blankers and should not be thought of as a DSP device or something that they are not, like a notch filter or IF shift and etc. They will do a fine job of eliminating ignition noise as well as eliminating the electric mixer or blender noise from the kitchen...... however they will not remove static crashes or quieten those atmospheric noises on 75 meters during summer time thunderstorm season activity.
Hope this helps!
Apr 15, 2009 | Radio Communications
18 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
