I have a Kenmore Elite HE3 washer model W10119648. Recently I been having an error message F71, it will not complete the wash, error F71 comes up and it stop. Can you help?
SOURCE: Control Panel
I have encountered the same problem and now I can use my washer again. Yay!!
Thank you.
Posted on Dec 02, 2007
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
SOURCE: Kenmore Elite HE3 front loading washer
Before you go crazy trying to solve the F2 code make sure the filter is clear. Disconnect the power cord, PLEASE. Remove the kick plate on the bottom front by removing the 3 screws below it. You will need a hex socket and extension or a torx screw driver. If there is water in the machine and it will not drain you will need a shop vac and some old towels to catch the water when you open the filter. Now, you will see the filter in front of you. Have the towels ready and vac turned on. Quickly unscrew the filter cap and stick the vac hose right in the filter to catch the water. Clean the filter cap. Did you find any socks, money or other debree ? If yes that may have been your problem. Put the filter back on and HAND tighten well. Test the machine. From now on empty all pockets before you do the laundry. You just saved yourself a big repair charge. Be proud of yourself.
Posted on Apr 17, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE3 F02 error
If you checked the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: what is the F35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 08, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
    Search Results
      Why am I getting an FL error code on a Kenmore Calypso ...
      www.shopyourway.com > Manage My Life > Questions
      I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
      fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
    Jan 27, 2016 | Washing Machines
    Keeps Stopping and saying UE
    uE error code 79631512210 Kenmore Elite Washer - Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
    UE Error code on my front loading Kenmore washing machine
    Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
    Jan 21, 2016 | Kenmore Washing Machines
    F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
    what's f24 code? - Kenmore Elite HE3 Washing Machine ...
    https://www.ifixit.com/Answers/View/85549/what's+f24+code
    iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
    F24 Error Code on My Kenmore Washer ' eHow
    www.ehow.com > Home
    F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
    Kenmore HE2 Plus Front Load Washer F24 error code ...
    www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
    ...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
    I have a Kenmore HE2T error code F24 - Fixya
    www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
    Dec 9, 2009 - Posted on Dec 09, 2009.
    Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
    I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
    F71 points at a connection error between button pad and control board.
    Please read the indications in this article: F70 and F71 are two logic board error codes...
    Regards.
    Nov 07, 2010 | Kenmore Elite HE5t Washer
    I have gotten F70 and F71 messages and the door will not open. What do I do about this?
    Hi.
    Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
    F70 and F71 are two logic board error codes that point at a communication error between the main log...
    Regards.
    Ginko.
    Jun 23, 2010 | Kenmore Elite 45986 Front Load Washer
    Takes almost 2 hours to complete a wash cycle
    Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
    http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
    -Todd
    Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Kenmore Elite H3 Error Code F71
    The computer needs to be reset most likely. You might try turning it off, uplugging the washer, leaving it off for a bit and starting over. They are touchy little machines, I've found, not just your brand either. Mine comes on everytime the power blinks on and off in a storm :0) Best of all have a look in your manual and if you don't have it go to the manufacturer's site and download a new one or look for support there. Good Luck to you.
    Jul 31, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    41 people viewed this question
    Top Washing Machines Experts
