Question about Toys
I have a smart trike 3 in 1 and i can not seam to drop down the foot rest made for the smaller children when not using the peddles, i push the button and try to pull down but it seems to be stuck, is it faulty?
3 Suggested Answers
  • 110 Answers
SOURCE: Hi we have purchased and
Contact the Customer Service Department:
• Replacement Parts, Warranty, or Issues with your Little Tikes product
» Order Replacement Parts * - All replacement part sales are final(No returns on parts orders)
» envelope.gif Email Us by sending an email to littletikes.cares@littletikescare.com. Please include your contact information and your question or inquiry
» Call Us at 1-800-321-0183
In North America
800-321-0183
8 a.m. - 8 p.m.EST(M-F) (GMT -5)
9 a.m. - 2 p.m.EST(Sat) (GMT -5)
Little Tikes Consumer Services
2180 Barlow Road
Hudson, Ohio 44236 USA
In the United Kingdom
0-800-521-558
9:00am to 5:30pm (GMT)
Consumer Service, Little Tikes Ltd.
900 Pavilion Drive
Northampton NN4 7RG
ENGLAND
Posted on May 22, 2011
SOURCE: Just ranover wheel on Little Tykes 3 in 1 Smart Trike
maybe you should look in the mirror when you back up or get a reverse camera from canadian tire
Posted on Aug 07, 2011
I plugged the sewing machine in it started working but my foot was not on the peddle looked and button was not stuck under peddle so what do.
The pedal pushes on the button which is nothing more than a on/off switch. Even if the button is not currently depressed, there could be a short inside. If yours is the type with a removable pedal, unplug it and see if the machine stops. If it does, there is definitely a short in the button.
Mar 04, 2017 | Sewing Machines
Why does the needle keeps getting stuck in the bobbin
Sounds like you've got a thread jam going on. Take the bobbin and bobbin case out, take the needle plate (=throat plate) off the machine, and clean all the lint and bits of thread and other gunge out of there. Reassemble. Rethread with the presser foot up. Fetch up the bobbin thread and pull bobbin and top thread ends under and behind the presser foot. Then start each seam like this:
1. Fabric under the presser foot; lower needle with handwheel or needle up/down key into the beginning of the seam.
2. Drop the presser foot.
3. Hold the ends of the bobbin and top thread behind the presser foot while you take the first 2-3 stitches
4. Drop the thread ends and sew normally.
See also the last pair of photos here: http://www.picturetrail.com/sfx/album/view/22521551
Feb 10, 2014 | Janome Hello Kitty 11706 Mechanical Sewing...
Smartrike front wheel won't turn with pedals once on the ground
Old question but I just needed the answer and figured it out. On one side of the wheel there is a disc with two arrows, line this arrows up with the arrows on the wheel and push the disc into the wheel until it clicks into place. Pull it out to convert back to a stroller.
Nov 29, 2012 | Kent International Smart Trike Sport...
1991 GMC Sonoma manual transmission won't shift into gears, won't move, is it the clutch?
Usally when the clutch is bad, you still can shift gears. Check the slave cylinder or air in the fluid line. Good luck
Dec 11, 2010 | 1991 GMC Sonoma
I just did the same thing.. were you able to get a replacement wheel?
Mar 21, 2010 | Little Tikes Swing Along Castle
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
I have emerald 183 and i can't figure out how to use the buttonhole feature. it keeps sewing just one side. also where exactly do i put the button?
Make sure you have pull down the arm that will engage the button hole mechaizm. Put a button in the back of you button hole foot, attach foot, reach up on the left side just below the light and pull the lever down, choose the button hole , lower tension to 3 and sew out the button hole. The button hole foot should push on the arm when it gets to the end and complete the rest of the button hole. If the columns do not match then it has to be serviced by a husqvarna dealer.
Sew Technologist
Apr 21, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Toys Logo
81 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
