Hoiw to put a lock on my router so that it cannot be used by any one in the neighborhood. Windows 7
  • Alex May 21, 2011
    Please specify the model of your router and start-run-cmd ipconfig /all command output
    Sergeant:
    Champion:
  • 218 Answers
There are multiple methods depending upon your model of router and if my initial advice doesnt stear you in the right direction then I will need these details
The easiest method is to logon to the router console, and look for the settings that say enable WEP or WPA security under the WIFI settings box, WEP is more compatable with older computers, however WPA is more secure
Another method is resticting access to MAC addresses, and I can walk you through this if required, however it is a more complicated proceedure to a non techie.
I hope this helps, you may need to look in you manual to discover how to logon to your router if you have it, however if not, let me know and I will see if I can discover a copy of it online for you.
If this helps, please rate my solution.
Andy
Posted on May 21, 2011
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Hoiw do i find my wpa on my router
go to d link assistant and it will give you the wpa key or look at back of router it should be there also
Jan 25, 2011 | D-Link DIR-615 Wireless Router
How do I secure my router? I think someone else in the neighborhood is using it.
You could use the CD supplyed with the router but i prefer using the web interface
DO THE FOLLOWING USING A CABLE NOT WITH WIRELESS CONNECTION
Open Explorer/Firefox then enter the IP address of the router in the URL bar (if unknown and the router is your DHCP server, use IPCONFIG command in a terminal window to find out)
after loging in (user+password) if unknown try default credentials
goto *wireless setup* and the basic things you need to do is entering an SSID (the name windows wil find in wireless connection), try to put something that wont give away your identity or location (a good choice is a word in some other language that you remember)
second is the enchryption level (the worse one is WEP 64 bit), the best is WPA2, WEP uses HEXADECIMAL charactors from 0 to 9 and A to F not hard to snif with good hacking tools, WPA2 uses phrases, for the best security in WPA2 again i recommend a long word you INVENT (not from a dictionnary) ownly you can remember, than if you want bullet proofing you could enable the option to hide the SSID and use MAC filtering so ownly the computers with the MAC address you entered will be able to connect
Hope it help ya
Dec 31, 2010 | 2wire HomePortal 1000HW DSL Modem and...
Is Encore ENHWI-N3 Wireless Router windows 7 compatible?
You should be fine using it with Windows 7, as there is no drivers as such for the router, you are just using the wireless (or wired) connection to the router, and windows doesn't really care how it gets there. As long as the adapter you are using to connect to the wireless network is windows 7 compatible you should be fine.
Hope that helped!
Oct 16, 2010 | Encore ENHWIN3 Wireless Router
Windows 7 asks for 8 digit on the router (615) I only have 7 digits
turn over the router and it will be there failing that then you can use an eathernet cable to the computer/laptop and use the d link server adress to go into the router and find the pass code put 192.168.99 into the address bar and take it from there hope this helps
May 15, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have a TP LINK TD8817 V3 ADSL router and I lost drivers
I cant think of any reason that why it should not work with windows 7 as it has no link with the operating system being used.
Mar 06, 2010 | Computers & Internet
My wireless router was working then the wireless and security light are now off. Wireless internet is not working
Someone in your neighborhood got into your router and turn it off, so they can get and use your internet connection. I would reset the router by the reset button, and right away put a password on it, and then use mac address filtering on the router. This will only allow your computer access to the internet.
Aug 09, 2009 | Belkin N1 Vision Wireless Router
I cannot set password
There are 2 users in this router, 'admin. and 'user', default password is blank. admin can change password of user without having old password, user can change his own password, admin can change password of his own by supplying his old password then new password twice. To log in to this router, default address is http://192.168.0.1 user name admin and password blank. You may now change password from tools menu.
If you forgot user password then log in as admin and change password, If you forgot all password then only way is to reset router from rare pin hole. Pressing reset for 20 seconds.
Jul 15, 2009 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
