My Laptop doesn't read Datatravelers , but i see it in the Device Manager but with a yellow Triangle .The laptop is new but i can't copy any thing to it!
  • 8,404 Answers
Open your "Device Manager" (right click my computer - find the device manager) - find the device with the yellow triangle - click properties. It will tell you the problem which you can then repair.
Posted on May 21, 2011
My NEO Basic B3362N doesn't work the webcam
Please go to Device Manager. Check under Imaging Devices if there is a yellow triangle with exclamation point.
Mar 01, 2013 | Computers & Internet
My va10 is not reading an sd card i have inserted into the slot
Open computer window and check the drives to see if any show your card. If so double click to open, if not, check device manager to make sure the drivers are installed for your portable devices. On the start menu, right click computer and click manage, in the left pane under computer click device manager and look for portable devices in the main window. Check there is no yellow or red icon next to it, if there is you will need to install a new driver.
Mar 11, 2012 | Sony VAIO VGN-AR605E 17" Laptop
When i first installed the audio driver for my hp pavillion entertainment pc dv6748us laptop, it is working, but after a couple of shutdowns it's not working again. what shall i do? please help me....
Go to My Computer/ Properties/ Device Manager - is your device listed? Does it show a yellow triangle or a red mark? If so, delete the device and reboot your computer Windows should identify that the driver is missing and reload it.
If this doesnt work, go to www.hp.com/support find your computer and get the driver you require.
Thanks for your question @ FixYa.com
Sep 13, 2011 | HP Pavilion dv6748us Notebook
Wifi doesn't work on my dell vostro with xp
wifi doesn't work on my dell vostro with xp ?
you must have a wifi driver check it device manager goto start --> my computer -->right click then properties goto hardware tab check for your wifi driver is installed... find the yellow question mark... then try to install it...some wifi have a security you need to know the security code... ex. wep.. etc,.
HOPE IT HELPS GODBLESS!
Jun 28, 2011 | Dell Vostro 1510 Laptop
My daughter deleated stuff off my laptop now i have no sound, what can i do
Hi Mark,
first thing I would suggest would be a sytem restore, this may sory your problem and other problems caused by the deletion of files which you may not have come across yet. Goto Programs->accesories->system tools and select system restore. Follow the prompts which appear on the screen and see if that solves your problem.
If the system restore doesn't work, then goto control panel->device manager and look for any items with a yellow triangle containing an exclamation mark, these are items which are experiencing problems. Right click on the problem hardware and select update driver software. The system will now do a search for the drivers that are required. Hopefully, windows will find the drivers you require and all will be good. If windowns fails to find what is needed, then it may be necessary to go to the manufacturers website, look for any identification for the hardware in the device manager and use a search engine to look for drivers or, if your pc was purchased as a ready built machine, try the manufacturers website of the pc itself (e.g. Gateway/Dell/Emachines)
Hope that this has been of some help.
May 07, 2011 | Computers & Internet
Already did that and on the command prompt its saying ip address n mac address not available
goto control panel->device manager and check in the network connections part to see if your adapter is listed, if it isn't then restart your machine and check again. If it still doesn't show, check that the network connection in question is securely fitted ( if it is an add-on card) There may well be a yellow triangle next to your device in the device manager, this will indicate that you have a problem with the device itself.
May 05, 2011 | Computers & Internet
I have a compaq laptop and my cd/dvd frive is not reading any cd's and in device manager it has a little yellow triangle and i cant fix it please help me !!!!!!!!
Sounds like the device driver for the CD drive is corrupted, Try "Restoring" the computer to an earlier date by going in to control panel.
Jan 21, 2010 | Compaq Laptop / Notebook Video-336970-001...
System does not recognize CD/DVD Drive
The yellow triangle means there is no driver installed. There is 3 ways to get a driver. In most cases you right click on the hardware in Device Manager and download driver or reboot and Plug n Play should pick up driver automatically. If none of those work then the only option is to load it thru the add/removal in the control panel using the disc that accompanies the softeare.
Apr 01, 2009 | Dell Studio 15 Laptop
My cd rom is not reading i think it is missing a driver
The yellow triangle is signifying that there is a problem with the drive. Usually it is a driver that has gotten corrupted. Try uninstalling the drive in your device manager then reboot. See if Windows reinstalls the drive automatically. 99% of the time this will fix the problem. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 04, 2009 | Acer (4432A-002) CD-RW Burner
Pioneer dvd-rw dvr-k17 problem
it's windows problem.
basically you need to edit (delete) registry.
follow this step from microsoft.
http://support.microsoft.com/kb/314060
Aug 05, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
