Please help,about my harman kardon sub ts11,buzzing loud noise came from sub even it is not connected,,..fuse is good,the power is goo.only buzzin.
  • 8 Answers
SOURCE: Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Do you get an indication on the display where the point of failure might be? It would show up on the LCD speaker diagrams just before shutting off.
Posted on Dec 28, 2007
SOURCE: Speakers Make a Very Loud Noise that Increases
speaker amplifier chip may leaky or damage
you are using improper sound driver
check driver status in your computer device manager or just typing dxdiag on run in start menu, check status of sound driver installation
Posted on Jan 17, 2008
SOURCE: two amp
my peavey is set at max,my subs are 2ohm so my amp will is set at 2ohm...
if i had 2 power amps,why would one sound louder then the other?
Posted on Feb 29, 2008
  • 34 Answers
SOURCE: Harman Kardon Sound Sticks Sub Problem
Oh well, buy new ones. What are harmon kardon sticks anyway?
Posted on Mar 10, 2008
Benimur
  • 6966 Answers
SOURCE: Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
My sub ts7 won't power on
check the cable , might be it burned bcoz of the voltage fluctations.
If not check the transformer if its buzzing or not. if not- buzzing replace the power cord
Aug 08, 2012 | Harman Kardon HKTS 7 System
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
My HKTS 7 Sub woofer makes no noise,the led burns from amber to blue as normal,and every so often i hear a low rumble noise. The Sub is powered and has 1 cable to the receiver, the fuse is also good.
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Dec 04, 2010 | Harman Kardon HKTS 7 System
Loud buzzing noise upon switching on
Do you have a wireless phone near the speakers? It will make the speakers noisy. If this is true, move the speakers away from the phone. Check other electrical devices which may be near the speakers, it may be the problem.
Jan 30, 2010 | Harman Kardon HK19.5 Computer Speakers
try uninstalling drivers and reinstall them.
also remove latest M.S update as some update cause more trouble than they are worth
May 21, 2008 | Audio Players & Recorders
HK AVR 225 front display not working
thats not good power transformers in it went bad do u have it on a nice power strip or direct to wall
Jan 19, 2008 | Harman Kardon AVR 225 Receiver
Jan 15, 2008 | Harman Kardon HK19.5 Computer Speakers
244 people viewed this question
 Grubhead
Grubhead
