Question about Continental CE-PAC1062 Air Conditioner
I have a Continental Portable airconditioning unit that I have to drain every couple of hours?
I do have a Continental CE-Pac airconditioner and every couple of hours it says to drain it. If we don't the unit won't run? Please help. [email protected]
    New Friend:
  • 53 Answers
Your problem is that u need a general cleaning ,an with out that u will still have that problem.Now if you have a little knowledge on how to open the system thats somthing u could do yourself..Once u get the system open locate the drain assembly ,make sure that pan an hose both are cleaned out an while you are there go ahead an clean the coils on the unit to prevent any head pressure an that the unit supplies air properly if you dont have any drain cleaner for your unit use ,bleach just a little cap full an pour in pan..an after you get it clean.once a year pour in drain hose ..That should take care of your problem
Posted on May 15, 2010
SOURCE:
I need a Continental Electric ce-pac1061-1 portable air conditioner user manual
Try Googling (continental)(ce-pac1061-1)(manual) without parens.
Sep 08, 2017 | Continental Heating & Cooling
How do you empty tank?
It is actually a pan with a float that when full will stop the unit.
On the back of the unit, bottom, there is a rubber plug. Have a pan ready and I would advise have the unit up on a couple of 2x4s or bricks...I used a short tube and drained it into a baking pan, it is too heavy to get into a bathtub or shower.
Jul 13, 2014 | DeLonghi PAC C120 Portable Air Conditioner
Tengo un aire portatil continental modelo CE PAC 10651 y se le partio el aspa que lleva en la parte de atras. donde puedo adquirir el repuesto por internet o hay un proveedor en Venezuela al cual pueda...
i no pudo localizar a ning?n proveedor parte de Venezuela. y, ¿puedo localizar una tienda que te pueda ayudar. si usted todav?a tiene el manual del usuario, buscar un n?mero de tel?fono de contacto, que puede llamar.
Aug 17, 2011 | Continental Dublin Series 13,000 BTU...
Airconditioning problem on 92 cavalier
Your Orifice tube is probley clogged and needs replaced i wouldnt recomend this be done by someone not trianed to do tho also with new laws regarding freon unless you have acess to a reclaimer it is illegal to do becuase entire sytem has to be drained to get to tube
Jan 12, 2010 | 1992 Chevrolet Cavalier
Delonghi pac w160a...''no water symbol'' stops on in airconditioning mode even though water tank is full
In the back of these units where the cord pulls out, there is usually a red reset button, try pushing that to reset the unit, also make sure the filter is clean, pulls from the top out of the unit. Make sure the coils are clean as well behind the filter.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 12, 2009 | DeLonghi Air-To-Air Portable Air...
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Continental CE-PAC1062 Air Conditioner Logo
331 people viewed this question
Top Continental Heating & Cooling Experts
Shawn DuRee
Donni Steen
jasbo
jasbo
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
