Question about MaxSlag FaceDub
When the application first opens an error message caode 0013 apears - i can select a template but i\ cannot select a face pic the screen freezes
An error have ocurred
my face book is loked and im going to face book i have id password but ti is ask me sicuty qasitn im give him my cell namber but it is not give caod namber
Aug 14, 2013 | Computers & Internet
How do I set up an out of office message in Outlook 2010?
You can create part-time or temporary 'Out of Office' automated replies in Microsoft Outlook. These can be set so that whenever you leave the office, an auto reply is sent.
This is useful if you have a high volume of e-mail messages and are expected to reply to them quickly.
You can fully customize your auto reply in Microsoft Outlook 2010.
Launch Microsoft Outlook from the Start Menu.
Click "New E-mail." Click "Plain Text."
Enter the message for your out-of-office reply in the main body of the text.
Click "File," then "Save As." Click the "Save as type" list and select "Outlook Template." Enter a name such as "out of office" and click "Save."
Click "File," then "Info." Click "Rules and Alerts," then "New Rule."
Click "Start from a blank rule," then "Check messages when they arrive," then "Next." Set "Sent Only to Me" in the conditions list and click "Next."
Select "Reply using a specific template," then choose "Specific template" on the next page as well.
Click "Select a Reply Template." Choose the template you already created and click "Open." Click "Finish," then "OK." All e-mails will now have the out-of-office reply. Disable it in "Rules" to switch it off.
Hope this helps
Oct 26, 2012 | Microsoft Outlook 2010
I have a yahoo business email account and I am using outlook 2007 to access my emails. I would like to use the auto-reply in outlook to alert all incoming emails that I am out of the office
Hi Cecil,
First you'll need to create a message template.
  1. On the File menu, point to New, and then click Mail Message.
  2. On the Options tab, in the Format group, click Plain Text.
  3. In the message body, type the message that you want to send as your automated reply.
  4. In the message window, click the Microsoft Office Button za010077102.gif and then click Save As.
  5. In the Save As dialog box, in the Save as type list, click Outlook Template (*.oft).
  6. In the File name box, type a name for your message template, and then click Save.
Once the template is finished, you'll need to set up a new rule to reply to the incoming messages.
Do the following:
  1. On the Tools menu, click Rules and Alerts.
  2. In the Rules and Alerts dialog box, click New Rule.
  3. Under Start from a blank rule, click Check messages when they arrive, and then click Next.
  4. Under Which condition(s) do you want to check?, select the sent only to me check box and any other criteria that you want, and then click Next.
  5. When you see a dialog box informing you that this rule will be applied to every message that you receive, click Yes.
  6. Under What do you want to do with the message?, select the reply using a specific template check box.
  7. Under Step 2: Edit the rule description (click an underlined value), click a specific template.
  8. In the Select a Reply Template dialog box, in the Look In box, click User Templates in File System.
  9. Select the template that you created in the previous section, and then click Open.
  10. Click Next.
  11. Optionally, select the check boxes for any exceptions to the auto-reply rule.
  12. Click Next.
  13. Under Step 1: Specify a name for this rule, type a name for the auto-reply rule, and then click Finish.
Hope this helps!
Please don't forget to rate;)
Gary
May 18, 2011 | Computers & Internet
How to add signature on text messages
There isnt an exact way to add a signature at the end of the txt. In order to do so, you have to create a template with your signature, then insert the template at the end of your txt. However, know that it will count towards the 160 character limit. Instruction from the user manual (pg 38-39) below. Hope it helps!
Message templates
When you often use the same phrases, you can save the message under template messages. Adding the message as a template
  1. Press Menu > Messaging > Templates.
  2. Press Options > Add New.
  3. Write the frequently used message > Options > Save.
Sending a message with template
  2. Select the message to send.
  3. Edit the message > Options > Send.
note: You can add a template while writing message. Write a message > Options > Add Template. Choose Text or Multimedia and select the message to add.
Mar 08, 2011 | Pantech Cell Phones
How to print envelopes?
use the hp software ..and use the envelopes templates in the setup of the page ..or ...just open Microsoft office word ..and select the mailings and in the left side will be the envelopes template ..(office 2007)
Jun 03, 2010 | HP DeskJet 940c InkJet Printer
Can you save a text template to be put on your texts every time
Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
Mar 28, 2010 | Samsung Propel A767 Cell Phone
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 20, 2009 | RIM BlackBerry 8800
MS word not responding
Rename all instances of your document template files (Normal.dotm or Normal.dot) This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.
Renaming the template lets you quickly determine whether the global template is causing the issue.
When you rename the Normal.dotm template in Word 2007 or the Normal.dot template in Word 2003 and in earlier versions of Word, you reset several options to the default settings. These include custom styles, custom toolbars, macros, and AutoText entries.
Dec 15, 2008 | Microsoft Office Outlook 2003 for PC
System error 0013 benq DC E610 DIGITAL CAMERA
i had the same problem but now i have solved it.........its not a software problem..... the lens in fornt of the camera is not able to come out......just hit the camera 3-4 times on a table it will start working.......hope your problem is solved
Mar 01, 2008 | Nikon Coolpix 3200 Digital Camera
Locked or wiped?
Hi , i had the same problem when i went to the download site to make my device up to date , a red x apear in bottom right of the screen and everything freeze , i call the help line and they make me format the harddrive inside the device , i format the device by going to my computer and locate the storage mine was f: , after formating the device i go back to the tomtom home software version 2.1 and download the application software version 7.162 and the map software usa-canada version 710 , install first the application and then the map , after that be shure to click device at top of the tomtom window and click disconnected device , after a message will apear with (you can safely disconnect your device) , i whent outside for a try and it came back at normal operation , hope it will help , good luck !.
Jan 14, 2008 | Tomtom ONE GPS Receiver
Computers & Internet Logo
88 people viewed this question
Top MaxSlag Computers & Internet Experts
David Payne
David Payne
Are you a MaxSlag Computer and Internet Expert? Answer questions, earn points and help others
