Question about Dryers
Everything working fine but drum not turning - Dryers
  • 2,510 Answers
Check that the belt has not broken or come off the motor pulley. Remove the top cover by removing the screws at the back of the machine and sliding the cover off forwards. Now you need to obtain access to the complete circumference of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum and under the bearing retainer, which may entail removing the back cover as well. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor or the tensioner. Good luck and please rate this solution.
Posted on May 21, 2011
Bosch Maxx wfl 1300 washing machine - drum making loud squeaking noise.
sounds like bearing have failed or the stainless steel drum has detached from its carrier open the door and try to move the drum up and down there should be no movement at all if there is machine will need to stripped down
Mar 03, 2014 | Washing Machines
Iv got band hero for ps3 and iv set it up and sync them. Da guitar and mic r working just fine but when i try conect and sync da drums it doesnt work. Da lights on da drum control keep flashing. Cn you...
Make sure you are syncing the drums by using the charging cable that is used for controllers. If you plug it in like that then turn on the drums it should sync up. If you are still experiencing the problem I suggest restarting everything and try syncing the drums by themselves without any other instruments, then connect the others.
I hope this helps!
May 16, 2011 | Video Game Consoles & Games
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
Apr 25, 2011 | Asko T700 Electric Commercial Dryer
When the dryer starts it makes a quick grinding noise like it is having trouble starting. After only 1 second that noise goes away and the dryer appears to be working fine. It will stay running anywhere...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 09, 2011 | Whirlpool LER4634J Electric Dryer
Drum error Brother DR350 take drum out and slide blue tab across corona wire and return drum to printer. Error message will not go away
Here's how I fixed it. Remove assembly from printer, and remove the toner cartridge. Using cotton balls, wipe the drum clean, turning it a quarter turn each time between wipes. When you have a clean drum, replace everything, and it should work fine till next time.
Feb 10, 2011 | HP Office Equipment & Supplies
Drum wont turn
Check the drum belt -- have to remove the top/front of the dryer.
Apr 28, 2009 | Dryers
The dryer drum won't turn. Everything else seems
If you can hear the motor running when it is turned on then you dryer needs a new belt. If you cannot hear the motor running it needs a new motor.
Apr 11, 2009 | Kenmore Dryers
ImageRunner 400S works, but prints a blank page
check the drum is seated well or not,check the drum drive lock, check the drum is rotating freely or not.check the chargin g rollor are seated well or not
finally replace the drum and see the result.
best of luck.
Aug 13, 2008 | Canon imageRUNNER 400S Copier
Dell 3100CN Error Message
I am a publisher here in Seattle printing full color books with this machine and I have just gotten the same message- Does anyone have a solution- I have Googled and checked everything... Now, this happened to me a few months ago and I pulled out the drum and sprayed it with air, replaced it and it worked fine for about two months- now I get the error again- does this help in the problem solving?
Jul 01, 2006 | Dell 3100cn Laser Printer
Dryers Logo
Top Dryers Experts
