Question about Marantz CDR510 2-Disc CD Recorder
How do I record from an external source, whilst playing from the other CD drive?
    Brigadier General:
  • 8,546 Answers
Read the manual.
Register and download it for free at audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/marantz/cdr510.html
Posted on May 21, 2011
Poor sound quality from external line
it may be the recorder itself.. these smaller recorders arent known for excellent recording quality..what is it set for..also check the recording lens and clean with a duster spray..it may be dirty..
Jan 19, 2014 | Tascam BB-1000 Portable CD/SD Recorder
I have a Yamaha MCX-1000 music server and the CD drive has failed. Where can I get a replacement?
I had the same problem. LOVE that Music Server. Icouldn't find how to replace the CD drive, since it's no longer sold. MyAV guy didn't have a fix either.
So instead, I'm using the External CD Input. I had a bunch of problems setting it up, but finally got the settings right and it works fine. But it doesn't grab the artist/song info so I had to input that manually. At least it's a way to add new cds.
We connected our external cd player via theanalog input. On the server front panel, make sure you have the sound level forthe "Analog Record Level" dial input (far right button on front) setto midway.
On the top menu (hopefully you're using a TV for this), go toRecording-Store from External Source. Choose "Analog" forInputs.
REC Type: SYNCRO: full auto. Then select "StartRecording". Then go to your external cd drive and start it. Onthe TV screen you should then see the green bars for volume, etc, and it shouldsay "Recording" at top right. You should also hear the music.
Apr 16, 2012 | Computers & Internet
I own a LG.ADR-620 CD RECORDER, when i record from the in built cd to the cdrw and play back things sound OK, when i record from a external source to the cdrw and then play back i get interference only on...
When you record from an external source, the data transfer may be too slow to produce quality recordings. If you're able to download the external source first, then burn it to disk, it should produce good quality recordings.
Apr 15, 2012 | LG Audio Players & Recorders
TDK DA-5700 records from cassette to cd-R but nothing happens when I press FINALIZE and then PLAY (ENTER). Why?
Finalize is for multiple recordings. If its a single recording, its finalized by itself.
Feb 09, 2012 | Audio Players & Recorders
I have connected my phillips cdr785 recorder the proper way to record from an external source and I get the message "start source" on the cdr side when trying to record. And it never starts...
If you're recording an analog source the recorder won't automatically start. You have to start it in sync with the playback.
If you're trying a synchronized digital recording...
Page 28 of the manual says
Start playback on the selected source.
The CD recorder starts to record simultaneously and recording in progress is shown. The remaining recording time left of the CDR(W) is displayed.
Note: If you start playback on the selected source within a track, recording starts at the beginning of the next track or after 2.7 seconds of silence in analogue recordings.
Mar 05, 2011 | Philips CDR785 3-Disc CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
Sound card won't work with external input
Are you trying to record and listen at the same time? It doesn't usually work that way, the computer has to process and encode the audio signals before they can be listened to. Once you restore the computer, are you able to listen to the recording? If you have onboard sound, rather than a separate sound card, all the audio processing is done by your CPU. If you are trying to listen to the audio as it is being recorded, you are probably overloading the capabilities of the device and its shutting itself down. Try to record without listening. Also make sure you have the latest drivers. If it is onboard audio, check the manufacturer's website for updates. If you know that it is Realtek AC 97 (probably says so your manual), you can download new drivers from the Realtek website.
Dec 09, 2008 | E-Machines emachines (emachinees) CD-ROM...
I cannot get the CDR510 to record from an external source. At first impression it appears that the analog line-in jacks don't work.
make sure you have the recorder source control turned up and the external device in the input or aux. be sure the external source is sending a signal and not padded or turned down
Dec 04, 2008 | Marantz CDR510 2-Disc CD Recorder
Marantz CDR510 2-Disc CD Recorder Logo
91 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
