Question about Jamo SUB 1810 Subwoofer
I was given a Jamo sub 1810, but have no instruction manual. I'm trying to hook up to my Pioneer HTP-2500 home theater system. What would be the correct way? Also if you could help me with the setup, that would be great. Thank you for any help.
    Brigadier General:
  • 8,546 Answers
Find it here...
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/779.aspx
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
Posted on May 21, 2011
Testimonial: "Thank you for your help. I didn't think I could make it work, but thought it was worth a try."
I had a picture until my child hit something on the remote and now i have no picture. I have sound. I can't figure out what button to press to get the picture back on my TV. I hooked the cable directly up...
The reset procedure will be in the owner's manual. If you no longer have the manual, look to the Pioneer website. They will have it if it's not too old. Should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through my website. Thank you.
Sep 29, 2013 | Pioneer Dolby Digital 5.1, Pro Logic II...
Do jamo powered subs work in the u.s.a. on 110 volts 60 hz
just buy a adaptor like a normal plug socket that your 2 pin 110 volt can plug into it then plug it in to the 3 pin 240 volt socket an bobs your uncle your sorted.
Jan 25, 2013 | Jamo A320 Hcs6 Home Theater Speaker System...
I want jamo sub 1810 circut diagram
Check out this link:
http://2getdtv.com/directv/stereo_receiver_codes.html?phpMyAdmin=ed9585cdc5a4551847999cb4dbcce76a
Feb 22, 2012 | Jamo SUB 1810 Subwoofer
Yes does anybody know how to hook up a two channel amp to two 12" subwoofer's
Active or passive subs (size is irrelevant)? Do you have the manual(s)? It might talk about that. If active subs, get an RCA splitter cable and share the subwoofer output.
Jun 14, 2011 | Pioneer 750-Watt Home Theater System,...
I have a pioneer home theater HTZ585 DVD system. Since yesterday, i get 'SUB COM' message displayed (blinking) and nothing seems to work anymore. Any suggestions?
I can't find that message in the manual but I would guess it's trying to tell you something is wrong going out to the subwoofer. Trace the wiring. If you don't see anything wrong, disconnect the sub and see if the message disappears or changes.
Apr 30, 2011 | Pioneer 740 DV Home Theater System System
I have the VSX-1019AH-k Pioneer receiver and i want to increase the bass. When i go to setup for the speakers the SW option is grayed out so i can't put it to plus. Help?
I'm referencing a VSX-1016 manual, so I hope it's close enough to help you find the function...
Somewhere in the System Setup menu you'll find a setting for SUB W. The wrong setting is NO.
Set it to YES or PLUS depending on if you want ONLY the Sub to carry all the bass, or if the Front Speakers will share bass with the Sub, respectively.
Dec 25, 2009 | Pioneer HTP-102 System
I have a jamo 250 sub and dont know which coax input to use
one will do just fine if you've tried one and its not working try to refer to manual on how to set up in the receiver function menus and if the sub is powered by an external amp which most are
Jul 03, 2009 | Jamo DVR-50 System
Pioneer HTP-100-SW
i just installed my htp 100 sw. the scheme was atached to the back of the woofer for me tho. easy. front speakers go into the sub in the two botom inputs from the receiver. the two upper are outputs to the actual speakers. hope it helps
Dec 24, 2007 | Pioneer HTP-102 System
Subwoofer
I suppose that your system requires an active subwoofer, and that you provide one. Some systems, if SPEAKER SIZE in SETUP are set to LARGE for front or center speakers, do not send signal to sub, system redirect signal to front or center speaker. Try to check this.
Oct 05, 2007 | Pioneer HTP-2900 System
Pioneer htp 2950 home theater system
There is a problem with the volume controller chip, or a problem in the paoer supply feeding the main amp. Good Luck
Jun 19, 2007 | Pioneer HTP-2900 System
Jamo SUB 1810 Subwoofer Logo
440 people viewed this question
Top Jamo Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
