Question about Ovens
Delonghi oven dfs 903 shorting out, does the control panel need replacing or could it be just a loose connection, it doesnt trip the the main box, just shuts the oven off.
3 Suggested Answers
  • 244 Answers
SOURCE: have a delonghi dfs 903 that was on lpg. now need
get on their website and check out their recommendation for the right injectors to replace your lpg injectors. delonghi is not a 'fly-by-night' company. they're well known & well respected! make sure you include your model#, and perhaps, serial# when you contact them!
good luck!
Posted on Oct 08, 2009
barkencoa
  • 3463 Answers
SOURCE: Hi there, The cooker trips the fusebox rcd,I
It is quite possible that it is the oven or grill element that is causing the problem.
You need to test them with a meter, to determine if they are o/k.
If you have no meter, then disconnect each one in turn, and try it again, this should isolate the problem.
Hope this helps you.
Posted on Dec 19, 2009
If you switch oven on it trips main power. what can cause that
Probably close to 50 things could cause that, but here are a few of the most common: Bare wire in a harness of the oven, causing a short-circuit in the line. Faulty plug on the power cord. Outlet in the wall is damaged. Loose wire in the outlet box, causing a dead short. Bad wire between the outlet box and the main breaker box. Weak breaker, or a breaker that isn't heavy enough to handle the load of the oven. (especially, if you just bought a new oven, it may need a larger breaker to handle start up.) Use a fused multi-meter (voltmeter) to check for these issues, and do not try to fix it if you are not familiar with electrical work. It could cause a fire, or give you a deadly shock.
Feb 12, 2017 | Ovens
Hi my delonghi double oven keeps tripping the electric power supply it trips on the top oven when using the grill and the bottom oven on oven
I would have a electrician look at the breaker switch as being in need of replacement. They do weaken over time and cannot handle the load that they were designed to carry when brand new.
May 13, 2016 | DeLonghi Ovens
Why does it trip breaker?
There probably is an internal short.
Oct 04, 2015 | Neff Ovens
We have a smeg a2a range , the main oven trips the consumer unit when we turn it on the small oven still works fine
You have a short, probably a wire came loose and is welded to the frame. I assume hte consumer unit is the braker for the stove in your panel.
Dec 19, 2014 | Ovens
Hob is tripping fuse box
If the hob is tripping the RCB or MCB on the consumer unit, there is a fault, usually in the elements or halogon heaters, you will need a multimeter to define but please ISOLATE FROM MAINS POWER BEFORE OPENING ANY PANEL
Some electrical knowledge would be helpful, check each element seperatly, you may have to carefuly disconect each heater on the hob, unless you know which blows the mcb, check all connectings to see thay are secure, work round the hab reostates, make sure there is no shorts to ground from elements, with temp control down at zero. Check wiring into mains as a loose connection will cause heat and mcb to trip.
If it is wired into the same outlet as an oven disconnect oven in case the other appliance is causing the problem. it is realy a question of eliminating causes one at a time, working round the affending appliance to define what is the cause.
Hope this is helpful
John
Jun 06, 2011 | Ovens
Keypad does not show anything. The lights work, the power is on, some buttons beep. The display shows no time or error messages
Ovens run on a 220 Volt circuit. That is two 110 Volt wires in reality, one from each side of the main. If one line is tripped only part of the oven will work. Check the Main for a tripped circuit. The range breaker should have a metal bar or pin connecting both halves of the breaker. If not it can trip on one side only. If you installed the "pig tail" yourself, turn off the main oven breaker and double check your connections. Black on each side (one may be red) and white wire in the middle. Neutral ground wire to metal plate of fixture.
If the power connections are correct and your panel still does not work it will probably need replacing. Do not open the access panel if it is under warranty (breaking a warranty seal will void the warranty) or you are not qualified to work on the wiring. It is better to call a tech without opening it. If you have opened it and then call a tech it will probably cost much more to fix as they will have to check ALL the circuits to be sure you have not damaged it.
Since it is a wall mounted unit be sure to check the wire for adequate slack and that it does not get crushed when the oven is installed. Metal Flex conduit is recommended (and may required in your area) between the wall supply box and the oven to protect the wire from shorting or damage.
Caution - 220 Volts can easily kill a person.
Apr 13, 2011 | Whirlpool RBD305PD Electric Double Oven
DeLonghi EOF260 tripping the circuit breaker
It is probably an element that is causing the trouble, as it gets hotter, the insulation resistance breaks down, and if there is a weak spot or hot spot it causes the trip to operate.
I'm afraid it is a question of elmination, trying different functions, until you isolate the problem.
Feb 09, 2010 | DeLonghi Ovens
Hi there, The cooker trips the fusebox rcd,I have checked for s/c's between l,n,e, but found none. The rcd trips after you set the clock and turn the main controller to any postion,ie oven light only, or...
Dec 19, 2009 | Tecnik TKC071/3 Electric Single Oven
Have a delonghi dfs 903 that was on lpg. now need to change injectors to natural gas but there are several different injectors to choose from. how do i know which is the correct one to order. my cooker...
good luck!
Oct 08, 2009 | Ovens
Delonghi microvave replacement bulb, microwave only 6 months old
I got a Delongi Mic form argos too ,model ED8525S-SBD, sounds like a similar problem to what happened to it last year. Issue is that the bulb explodes (mainly due to the very strong spring on the door I think) leaving filament lieing on the metal chassis, hence the trip switch in your fuse box trips.
Didn't manage to find a replacement bulb but at least if you remove the old bits then it will get the machine back up and running and stop the trip tripping!
Take off the top by removing the 4or 5 screws around the outer edge at the back. The bulb sits directly behind the front panel inside its own metal chassis. There is a diamond shaped black plastic flange which the 2 power wires feed onto. 2 metal lugs hold this inside the chassis. straighten the lugs and the bulb holder pulls out. Even with the bulb removed I think there was a blown fuse and I had a further issue with the turntable not turning(this feeds off the same circuit as the bulb). So maybe Argos were right - the machine only cost £80 at the end of the day!
Jan 31, 2009 | DeLonghi Ovens
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
