Question about InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector
Computer image does not cone out through the projector. the image goes blank immediate i connect it to the computer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Try doing a Reset All on the projector, which should be located within the User menu. i'd also check the VGA cable connectors on each ends, make sure there are no bent pins
Posted on May 27, 2011
Using a Dell projector, is there a way to get it to project white without any inputs, versus the standard blank blue screen? It goes white when searching for inputs, but switches back within seconds when...
Since you did not provide the make and model, you will have to pull out the manual and check the settings. It may provide you with a setting change for the background color. Perhaps you can connect it to a computer, open an new blank document and project the blank image to get your white light.
Mar 28, 2015 | Dell Office Equipment & Supplies
I have a Dell laptop ready to go with my first Power Point presentation. I check the projector out from the library and there are no instructions. I googled instructions and tried the advice: Push Fn and...
Look for the F-key with a square/icon of a laptop. Press FN+This button until you see your screen display show that it will be using your LCD + the output on your computer. Remember you need to hook both the VGA or HDMI out to the projecter as well as the USB cable.
Mar 03, 2011 | InFocus In2102 Projector
I am using a Dell lap top with Windows Vista to connect to a NEC VT590 projector. I want to show a PowerPoint presentation. As the computer is booting, the computer monitor is blank and the loading...
You need to configure the projector as a second monitor as explained here
http://www.online-tech-tips.com/windows-vista/multiple-monitors-vista/
Feb 02, 2011 | Computers & Internet
Input Screen shows a permanent image
resolution issue. reset the settings to factory default. if that doesn't solve it, make sure the resolution on the projector matches what is on the computer. and it should take mac ok. also check the cable.
Aug 27, 2009 | SharpVision XV-Z9000 Multimedia Projector
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Changing bulb
Upon setting up your equipment it is very important that you turn on the projector first. You will see a blank projection image, now turn on the computer, (confirm your cables are connected properly). When using a lap top computer you may need to disable your computer's display screen. First locate the "function" key at the top of your keypad that reads "LCD", "CRT" or it may have an icon that resembles a computer monitor. By pressing the "FN" key and the corresponding "function" key you will be able to obtain the image from the projector only. This is known as "toggling" the image.
for more info check this link http://www.avispl.com/service-support/projector-troubleshooting.asp#2
Sep 06, 2008 | Sanyo PLV-Z2 Multimedia Projector
InFocus LP530V Video Projector 2000 ANSI Lumens 6.6 lbs. DLP 4:3 XGA 400:1 (LP-530V, LP 530V) Multimedia Projector Logo
75 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
