Question about Stanley Bostitch Nail Gun
I have just brought a brand new bostitch bt1855 brad gun that i tested once it arrived, and it worked perfectly. the next day it only fires air and no brad. there's no jam or obvious problem. any solutions? cheers, al
  • 2,510 Answers
Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Posted on May 21, 2011
    Scholar:
  • 75 Answers
Returning it would be best IF there is something wrong with it but how likely is that, , might be an oversight especially if your unfamiliar to start with, 1. make sure you have it loaded and with the correct brad 2. make sure you have released the mechanism that holds tension on the brads ,( the thing you pulled back to load it with nails,it locks in open position to load, then you have to release it to push the nails and hold tension on nails 3. if all of this is good then you might think it is not firing a nail because all you see is a hole in the wood, there could be a nail down in that hole because it is supposed to countersink the nail too so you cant see it and for filling in with spackling.
Posted on May 22, 2011
I have already changed trigger valve assembly, O rings and all. Still leaks when I try to fire. Will not shoot brads just leaks lots of air around trigger assembly.
Most likely problem is the head valve orings not making perfect seal. Remove the head and pull out the headvalve piston. Apply plenty of white grease to orings and test fire. If gun fires, will need oring kit soon. Good luck
Aug 14, 2015 | Stanley Bostitch SB1850BN 18Gauge Brad...
Air leaking from trigger Bostitch SB1850BN
Most likely the orings or seals in the headvalve are not making perfect seal. Remove the head and pull out the headvalve. Apply plenty of white grease to orings and test again. If the gun fires, then will need oring kit soon, or just keep using plenty of grease. If the gun still does not fire, check that the safety foot is depressing the trigger valve all the way in. Good luck
Aug 13, 2015 | Stanley Bostitch SB1850BN 18Gauge Brad...
My bostitch bt1855 nail gun worked fine, until it started to dry fire 2inch nails. No problem with firing quarter inch nails. Any ideas?
Have you serviced it recently? and is the gas in date? The pistons do dry out and have to be oiled with special oil.
Dec 24, 2012 | Stanley Bostitch Nail Gun
I just bought the Bostitch SB1850BN 18 gauge brad nailer with the Bostitch CAP2000P-OF air compressor. When I hook the hose up and start the compressor, I cannot get the nailer to fire a nail. Only air...
Check the position of the switches and selectors. It sounds like you are in between settings. Also, put in a few drops of oil, and try your gun out on scrap wood, so oil doesn't come out on your good work.
--W/D--
Jan 21, 2011 | Stanley Bostitch SB1850BN 18Gauge Brad...
Bostich framing nailer won't reset. If I release air pressure it resets.
The new Stanley guns are a pain in the ***! I you don't oil them twice a day the rings get sticky,also if you don't use the regulator on the compressor for different nails it will over fire.If your pin isn't sticking then you need to return/contact Stanley cause their product along with the brad guns seem to be having problems!
Oct 22, 2010 | Stanley Bostitch BT200K
I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer gun. How do I adjust the depth the nailer shoots the brad nails into base boards? I see that their is a dial on the back...
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Jun 12, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
My brad nailer will not shoot any nails. When I press the trigger, I can hear a small puff of air.
it sounds like the piston/driver might be stuck or the firing valve is malfunctioning. there are 4 screws to remove the top cap and you can see if the driver is damaged. Also before removing check to make sure there is not a nail jammed in the nose assembly. This tool is good for breaking the pin on the piston.
Oct 16, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
May 20, 2009 | Stanley Bostitch BT200K
My gun fires 2 2in brads at the same time. Is there a fix for this?
most likly using wrong gauge brads check on gun for gauge size example 16mm 18mm ect.
May 10, 2009 | Stanley Bostitch BT200K
Stanley Bostitch Nail Gun Logo
619 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
