Question about Sony DCR-DVD101E DVD Camcorder
No picture in eye piece viewer
Vieqer dark but image is in the side viewing screen and won't record
  • robertljarm Aug 15, 2008
    I will end you more info tomorrow it is my budy at work camera
    Guru:
  • 1,894 Answers
Does the recording function not work?
and if you are able to record you said you are not able to see it.
but are you able to view the files in any external source.
Posted on Aug 15, 2008
  • 4,472 Answers
How long have you owned the unit? How long has it been doing this? Do all other playback functions work just not record? Once I have more information I will be happy to assist you further so please don't reject my solution until we have solved your issue.
Thanks,
Lee
  • Lee A.
    Lee A. Aug 15, 2008
    I look forward to hearing back any information you can get will be helpful.
    Thanks,
    Lee
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Lens screen stuck open and no image on LCD view screen.
It is jamming, the only really fix is to have it repaired, that costs a lot and it is sometimes better to just replace the camera.
Mar 15, 2014 | Sony Video Cameras
Backlight spoilt for dsc t90
When the display is to dark or to light, the manual says:
Adjust the brightness of the backlight (page 18).
On page 18 it says:
This sets the brightness of the LCD screen. When viewing images in bright outside light if [Brightness] is set to [Normal], reset to [Bright]. However, the battery power may decrease faster under such condition.
You also can press the button with the > logo, to change between view pictures and record.
Dec 08, 2013 | Sony CyberShot DSC-T90 Digital Camera
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
Hi, i am Lata and the problem i face is the screen appears dark with circular dots resembling stars in the sky on a dark night. Images cannot be viewed and when i click there appear some horizontal lines....
hi, i am del and the problem i face is the screen appears dark with circular dots resembling stars in the sky on a dark night. images cannot be viewed and when i click there appear some horizontal lines. what could be the problem? Can you help please? Rgds del
Apr 21, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
The screen went dark on jmv 111
Dark as in gone or dark as in the image is still viewable?  How does the onscreen menu look when the image is dark/gone?  If the onscreen menu looks right and the image is still dark, you might want to check the cables or another input.  If another device using different cables and another input looks fine, you may only have a problem with the input/cable you are using to view the movie.  If the onscreen menu is also dark, then I would think there is an internal problem that needs looking into.
Mar 23, 2009 | Jensen Car Audio & Video
Dark LCD screen
Have you tried using a manual aperture setting? Also try the back light function.
Jun 30, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Black screen in shoot mode
The most common cause of this is a failed image sensor. Usually the playback mode will let you view pictures taken before the issue happened just fine and you will also be able to view the menu system just fine. When viewing the screen in an image taking mode, however, there is typically discolorations, horizontal or vertical lines, image bluring or distortions, or simply a black screen.
This situation, if caused by the image sensor, has to serviced and cannot be fixed by the user. If you are within your one year warranty and no user damage has been done to the camera, the camera will be fixed at no charge. If beyond the 12 month period however the customer may opt to have the unit repaired at a cost or take advantage of the Canon Loyalty Program and upgrade to refurbished S3 IS at an alternate discounted price.
Hope this helps.
Sincerely,
HeavyDLB
May 31, 2008 | Canon PowerShot S2 IS Digital Camera
Won't record picture
it probably is the ccd imager. call sony and tell them about the problem. since they had a recall for this issue the may fix it for free.
Jun 11, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony DCR-DVD101E DVD Camcorder Logo
93 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
