Question about Frigidaire Electric Dryer
Frigidaire front loading dryer model LEQ2152ESO....runs fine but all of a sudden it just started making a rythmic "thumping" noise when turned on...is this an adjustment issue or a repair?
  • Frigidaire Master
  • 7,482 Answers
Hi ckteaque....
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Posted on May 21, 2011
Frigidaire gallery stackable dryer with a thumping sound
POSSIBLE BAD ROLLERS, BAD DRUM GLIDES, WORN BELT, DAMAGED BELT TENSIONER? AND BAD FELTS ON THE DRUM ITSELF
Feb 25, 2015 | Frigidaire Dryers
How to fix a Frigidaire Gallery Commercial Heavy Duty
Good Morning Friend,
I understand your Frigidaire dryer, model# GLER642A, is making a thumping noise when running, and you want to know how to fix this. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is causing the thumping noise. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire GLER642A Electric Dryer
What is the thumping sound in my frigidaire front loader dryer?
Hi Denise, thank you for your question. There could be a few possibilities of why your Frigidaire dryer is making a thumping noise. To better assist you; may I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can better address the issue at hand. Thank you - Z.
Apr 26, 2014 | Frigidaire Refrigerators
Maytag dryer tha-thumps
It is safe to use the dryer, I don't see any foreseen future to other parts. But the idler definately is flat(tening). It should be replaced asap.
May 24, 2012 | Maytag Dryers
Frigidaire front loading dryer model LEO2152ESO....runs fine but all of a sudden it just started making a rythmic "thumping" noise when turned on...
Hi ckteaque...
May 21, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire LEQ215EE1 dryer making thumping noise
Posssibly have a bad drum roller if mechanically inclined you can do this yourself but you need to take the drum out to do this
Nov 15, 2009 | Dryers
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Rythmic thumping sound
probably the rear bearing or the drum shaft
Nov 15, 2008 | Asko T701 Electric Dryer
Frigidaire  Electric Dryer Logo
366 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
