Question about Refrigerators
WHAT CAUSES YOUR FREEZER TO HAVE SOO MUCH ICE IN IT WHAT SHOULD YOU DO TO GET RID OF IT
  • 706 Answers
If it is an older style Freezer or one that is NOT FROST FREE, it won't dry the air that is drawn into it every time you open the door . The air around us is full of moisture and that is what builds up and freezes. Frost free systems dry that air out so you get less moisture which in turn means less ice build up. Hope that helps...
Posted on Aug 15, 2008
6ya staff
SOURCE:
Freezer stays cold. Why is fridge part warm?
if freezer gets iced up the fan designed to pass cold air from the freezer to the fridge stops working. The freezer is meant to go into a defrost mode when its trtansducer senses too much ice. If the transducer goes fault the ice builds up. Some fridges use a timer to work this out so it could be a timer fault. Talk to a service man about how much ice the freezer should have for them to sucessfully diagnose the fault. Too much ice may prevent the service man from working out if temperature sensor is working and no ice can prevent him from testing sensor. To get rid of ice you have to trun off the power to the fridge and let it melt.
BEWARE remove food to another freezer and fridge to prevent food going off or getting food poisioning
Sep 17, 2015 | Estate TT14DKXKQ Top Freezer Refrigerator
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Please someo one help our freezer is soo cold that everything is freezing very hard, but our fridge is not cool it's starting to warm up, i see can see where the cold air is suposed to come from,
You will need to replace the "bimetal defrost element" and the "defrost heater".
Here is a link to the bimetal defrost.
Here is a link to the heater.
You will need to empty the unit of food and leave the doors open for 24 hours so that all the ice buildup on the coils defrost before you can replace the parts.
Take a look at this video.
Oct 16, 2012 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice is collecting on the fan in the freezer causing whirring sound.
Reduce thermostat setting point by point till no ice accumulation on fan.
Oct 01, 2017 | General Electric GSH25JFX Side by Side...
Ice accumulates on the bottom of the frezzer
if frost free freezer then maybe drain tube plugged up with ice.defrost freezer and restart (unplug till ice melts)or drain hose is dirt plugged
Nov 23, 2011 | Samsung RS2630WW Side by Side Refrigerator
Little panel inside freezer door will not close and ice is building up on the door. How can I close the panel?
You'll need to defrost the freezer to get rid of the ice first. Trying to remove the ice can result in broken plastic....
Apr 30, 2009 | Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Whirlpool FUF20DPARWH Freezer
Was the door left open for a long period of time.? Sometimes this causes so much ice that it re freezes and can't clear the drain. The only solution is to unplug and let sit with doors open for at least 24 hours. to get all the ice off the coils. Then use a pipe cleaner on the drain then use a turkey baster to force water through. then a mild bleach solution. Check the door gaskets if they are ripped or loose or the door warped and not sealing tight this will also cause this problem. If this still doesn' t solve the problem it is probably a defrost problem Usually the timer or defrost thermostat.
May 18, 2008 | GE 20.3 cu. ft. / 575 liter Upright...
Whirlpool Refrigerator or freezer Doesnot cool
I have a similar top freezer and during the summer
I have had a problem where the frdge part does not get cold. The two holes coming from the bottom of the freezer to the fridge are blocked
with ice. I took the back part off the freezer
got rid of a clump of ice. I also used a hair dryer
in the fridge section to melt the ice in the holes.
Dec 11, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
