Question about Canon PIXMA MX310 All-In-One Printer
It starts to print in english, then just prints any character so it looks foreign......Why?
  • 385 Answers
Hi!!
Try un installing the driver and re-install it!You can Download the new version of the driver from www.canon.co.za or www.canon.com and see if it works!!
Hope it does!!
Posted on May 21, 2011
Garbage printing issue in Epson PLQ20
It sounds like you need to go to menu and set the correct language. If it is set with foreign language you will get garbage characters!
Nov 14, 2015 | Epson Office Equipment & Supplies
What can be the solution's, I am typing the letters on the keyboard and it is printing all different characters on the paper -- is there a command set that should be cleared?
First pull out printwheel and see if the "spokes" are even and straight, Second try a new wheel, and third, on this Brothers, when you turn it on the carrier has to go to the left and you will hear the wheel turn and cycle to the correct home spot. Some times there is a arm that comes out of the left side frame that loosens up and throws the time off, check for loose bracket on left side. But a new wheel may solve the problem Good Luck.
Jun 12, 2014 | Brother ML-100 Typewriter
My pound sign comes up as # and my @ as "
Windows 7 or Windows Vista
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type intl.cpl in the Start Search box, and then press ENTER.
  2. On the Keyboards and Language tab, click Change keyboards.
  3. Click Add.
  4. Expand the language that you want. For example, expand French (Canada).
  5. Expand Keyboard list, click to select the English(United States) check box, and then click OK.
  6. In the options, click View Layout to compare the layout with the actual keyboard.
  7. In the Default input language list, click English(United States) - English(United States), and then click OK two times.
  8. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  9. Click the Language bar, and then click English(United States).
Windows XP
  1. Click Start , type intl.cpl in the Run box, and then press ENTER.
  2. On the Languages tab, click Details.
  3. Under Installed services, click Add.
  4. In the Input language list, select the language that you want. For example, select French (Canada) .
  5. In the Keyboard layout/IME list, click English(United States), and then click OK .
  6. In the Select one of the installed input languages to use when you start your computer list, click English(United States) - English(United States), and then click OK.
  7. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  8. Click the Language bar, and then click English(United States).
How to make sure that the selected layout matches the keyboard Windows 7 or Windows Vista
  1. Click Start, type osk in the Start Search box, and then press ENTER.
  2. Match the keyboard on the screen with the physical keyboard to make sure that the layout matches.
  3. To check the uppercase characters, click the shift key on the keyboard or on the screen, and match the characters printed on the keyboard.
Windows XP
  1. Click Start, type osk in the Run box, and then press ENTER.
Jan 07, 2011 | Dell Computers & Internet
Dear expert pos machine(ibm SureOne100 Type :
looks like its running on IBM PC DOS. code page 708 - arabic. https://msdn.microsoft.com/en-us/library/cc195061.aspx however if you are using windows, then you may need an arabic windows, just adding an arabic languge file wont help. IBM PC Dos doesnt have an arabic option. you can download the ibm surepos 100 4613 technical reference manual which is what i did for you. but it no help in that arabic is not an option. research using arabic with DOS. because your keyboard is basically a PC one working in DOS.
Oct 03, 2017 | IBM SureMark Printer TF6 Thermal Label
Printer is printing foreign looking characters all on its own. No print jobs are being sent to the printer. Printer is set to DEC mode and the macro has been reloaded several times. As soon as you put the...
It sounds like data is being received by the printer from an outside source.
Try disconnecting the printer from the computer system so it is a free standing printer. Power the printer ON and put in ONLINE if you do not get strange characters printing the print job is definitely from the computer system some place.
If you do not get the print jobs printing when the printer is disconnected from the computer system, it could be that the print jobs are being sent from the wrong driver or print queue on the system, you may need to try to identify who is sending the rogue print jobs.
Feb 10, 2010 | TallyGenicom LA800+ Matrix Printer
Shift-3 does prints # instead of Btisih pound
This is because it is set to US english keyboard layout rather than UK English layout.
Go to Start -> Control Panel -> Keyboard
and change the language settings...
Nov 17, 2009 | Dell 0Y3740 Keyboard
Problem in Chinese chacracters printing , prints only junk !
there is nothing wrong with the printer ... the issue is the support in your computer for those languages...
May 29, 2009 | Computers & Internet
Web pages print ramdom characters
Try a different version I had it happen to me, so if it did it using 9.0 adobe acrobat reader I would go to 5.0 or 6.0 version instead and then it would solve my problem everytime it's a hassle but don't know any other way around so that's my best advice.
Dec 12, 2008 | Compaq A3000 All-In-One InkJet Printer
Would like to change Language settings for Epson Stylus Photo R290 Series Printer... Currently when printing a Test and when I go to the Print Preference, its showing as a foreign language... How can...
1. First of all, you must completely uninstall your current driver (with foreign language).
2. Download Epson R290 English Language Driver from here :
http://www.epson.com.sg/epson/drivers/driver_download.htm?dc=1&mode=3&mfalse&catid=1&pid=1259
3. Unplug your printer USB Cable from your PC
4. Run : Setup.exe
5. Follow the instruction, and thats it. You've English Language now :)
I have tried this and it worked :)
Aug 28, 2008 | Office Equipment & Supplies
HP Deskjet 6540 Alignment
Yeah, the only thing that can cause this is paper feed problems.
There must be either something loose in the paper feed mech (look for wobbling "tires") or there is still some paper or other foreign debris in the paper feed path.
Jul 03, 2008 | HP DeskJet 6540 InkJet Printer
Canon PIXMA MX310 All-In-One Printer Logo
142 people viewed this question
old marine
old marine
