Question about Belkin (54G F5D7230UK4) Wireless Router
How do I rename my network on a Belkin router
    Problem Solver:
  • 17 Answers
Please open the configuration page of your router by typing your router's IP address on a browser's address bar. Router's IP address is the default gateway when you check the IP address on the command prompt. As soon as you are on the login page, type the user name and password. Look for the wireless settings tab. SSID is the router's wireless network name. Replace the SSID of the name you want for your wireless network and apply the changes.
Posted on May 21, 2011
5 Suggested Answers
kornho
  • 781 Answers
SOURCE: need network key for belkin g+ router 802.11g
if you own the router and you don't know the network key or forgot it.
you need to reset your router, please check the intructions that came with it. if you haven't change the admin password (which is by deafult blank) go into the admin page and change or delete the network password doing something similar to this
if you don't have or can't remember the admin password you need to restore the router to defaults to reconfigure it
if you don't own the router and don't know the network key you need to ask the router owner for the key or use a program to hack into the router signal and attempt to figure the key out. (not recommended as it is ilegal)
Posted on Dec 25, 2009
Matteh
  • 83 Answers
SOURCE: Belkin Router
Ip adresses are SIMPLE to find, it doesn't matter what router you have, unless you are looking for local ip which doesn't seem you stated it
You could find your ip in theese following sites
www.ip-adress.com
www.ipchicken.com
www.whatsmyip.org
www.whatsmyip.net
Hope this helped!
Posted on Dec 01, 2007
steinja66
  • 52 Answers
SOURCE: network key for belkin router
are you referring to the Encryption key - the WEP key?  You need to get that from the person who takes care of the router.  If YOU are the person who administers the router, then you need to reset it to the default factory settings.
Posted on Apr 04, 2009
SOURCE: how do I rename it so I can further protect my network
How do I put a password on my belkin 54g to stop neighbours using my connection
Posted on Sep 19, 2010
Belkin N300 router, renamed network, having many issues with my 4 yr old Dell 1520 connecting to the net, network often say 'unidentified network'. takes lots of fiddling to connect. however,...
The best solution is to delete your network and create a new one
Also reset your Belkin Router to factory default settings.
This would take care of your issue.
If you need suitable assistance you can also get online technical support. I would suggest you to contact TheBestPcDoctor. I get my issues fixed by them.If you need you may also contact them @
www.thebestpcdoctor.com or via 877-407-9229
Oct 05, 2011 | Belkin Surf N300 Wireless N Router
Ipod touch will not connect to belkin wireless router.
If your Ipod touch will not 'find' your Belkin N router - or it did and then vanished forever try this- it worked for me.
1.Turn wifi off on your computer, ensure you have the latest firmware on your router,reset the router to factory default.Do this using a wired connection from the admin page.
2. Change the SSID name from what it was previously say from Belkin xyz to my router.
3. Power down the router wait about 30 seconds then power it back up.
4. As you reset to factory setting you will need to put in your internet access info again - do this from the admin page. Also set up your security at the same time.
5. Restart the router from the admin page.
6. Unplug wired connection start wifi and connect to your computer -make sure that you have full internet access from you computer - dont forget you need to connect to the newly renamed router.
7. Take ipod and make sure wifi is off.
8. Clear network settings.
9.Turn wifi on and it should find your newly renaned router - join and enter your pass key.
Why it does it I have no idea neither do Belkin or Apple but it worked for me - a trial and error solution !
Good luck
Mel
Jan 25, 2010 | Belkin (F5D7230-4) Router (587009)
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
How do I rename it so I can further protect my network
  1. Log-in to your router (default: 192.168.2.1)
  2. Go to LAN Settings
  3. Change Local Domain Name to a name of your liking.
  4. Click Apply Changes.
  5. Done.
If you have any more questions or this is not clear to you, just come back here and leave a comment - I'm happy to help.
May 22, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Problem with Mac and Belkin router
I have a Mac Pro and a Belkin F5D 7230-4 Router. The Mac links to the WiFi but will not go on to the internet. The Router works fine with a wired PC and other wireless PCs. I have updated the Belkin with the latest Firmware but it does not help. I have tried powering down the Router and Modem
Gmac
Feb 18, 2009 | Belkin (F5D5231-4) Router
Two pcs running vista home edition wired to router ok. laptop wireless ok. advent pc running windows xp wireless cannot see belkin router but can see outher router in my area. router is a belkin N wireless...
Check the router settings, if the router is set to only use 802.11N wireless it won't pick up a computer that is using 802.11G or 802.11B wireless.
Good luck
Nov 14, 2008 | Belkin Computers & Internet
Unable to access the network
There are two things you can try, one is renaming the SSID in the Wireless settings from the default (WLAN) to another name then release and re-new the IP addresses. If that does not appear to work try uninstalling the Wireless USB network adapter(s), reboot and reinstall and that should solve the problem.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Belkin (54G F5D7230UK4) Wireless Router Logo
2,217 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
