I have an LG LST244H-2 Split System Air-conditioner. I recently purchased the home where it is installed and am unable to locate the user manual. Could you please tell me how i turn on the heat function of this system. Which button on the remote do i use. It seems no matter what i press, i get cool air!! Thanks
  • lupa1985 May 25, 2011
    Thanks very much for the assistance. This has fixed my issue
  • 794 Answers
Hi lupa1985,
To turn the machine into a heater kindly follow these steps:
Press on/off switch and then press mode button still cool symbol * and then set your temp 23 by pressing And for heat press mode still symbol heat (symbol like sun), and set temp 29.
For the user manual, kindly contact LG's customer service because they will send it directly to your email. You may call them at 1 (800) 243-0000.
Hope it helps.
Thank you for using FixYa.
Posted on May 21, 2011
What is the difference between a ducted and non ducted Domestic Air Conditioner?
Ducted A/C has an internal fancoil unit installed in the roof space of the home. From this central location, a series of ducts run from it and into as many rooms in the house as the owner desires. From these ducts, this allows you to cool or heat each room individually – called zoning
Split systems stand out for their relatively low initial purchase price. Another perk is that the installation is not so invasive – it can often be done in a day or less from a licensed technician. Though, being that the unit is fairly small, it is best suited to cooling or heating one room – this is either a positive or negative depending on how you look at it. On one hand, it’s an efficient option if you only need to cool or heat one room, but on the other hand they are less effective in larger spaces. Rarely could a split system air conditioner cool or heat an entire home. Split system air cons are great options for small areas, but lack the power to affect larger spaces – this is reflected in their relatively cheap purchase price, from around $1,000-$2,000.
Aug 05, 2017 | Heating & Cooling
How to fix LG error code CH 23?
There is a problem with a sensor ,but it must to change both(because are 2 senzor )even is broken just one.this senzors are locate in outside unit.
Nov 21, 2013 | LG LSC091PMA Split System Air Conditioner
How to operate LG Split A/C LST244T-2
The file is downloaded at a 3rd party site where I store files. Just follow the LG LST file here - http://www.mediafire.com/?mmzafynmjgy
May 14, 2010 | Heating & Cooling
Retrofit newer Sanyo split AC system where old is installed
absolutly if you change refrigerants witch you prob would have to you may have to flush the linesets to cleen all the oil out but you should have no problems
Apr 08, 2010 | Sanyo Split System Air Conditioner
Lmv240he & lav181cnw
I searched the website but could not locate the literature for that particular unit. I recommend you contact the manufacturer's technical support department. They should be able to email you the manual and direct you how to obtain replacement remote controllers.
Technical Support
For technical support on a DFS, PTAC or TTW Product call 888.865.3026, then press 2.
I hope you find this helpful with your endeavor. Good Luck! :-)
Mar 08, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
540 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
