Question about Haier (B000194UBA) Compact Refrigerator
Haier (G2005605596) Compact Refrigerator interior light on compressor not turning on to cool . I hear the thermostat click on only near the zero number on the cooling dial . The dial has a center type button . Is this possibly a reset button for the compressor ? If not what can I check for replacement parts ? I realize that if it is the compressor it is toast, but I am looking for a simple cheap part replacement. Thanks for your time and knowledge.
  • 409 Answers
SOURCE: clicking near compressor but doesnt
since your mini fridge is under warranty, have a technician come and take a look at it. i would say it's the damper.
Posted on Sep 13, 2008
  • 1122 Answers
SOURCE: have a haier aes44b compact
IS THE COMPRESSOR RUNNING?IF NOT YOU CAN PUT A 3IN1 STARTER KIT ON IT($10)TO SEE IF YOU CAN GET IT TO START AGAIN,LET ME KNOW-MIKE
Posted on Dec 06, 2008
  • 400 Answers
SOURCE: haier compact refrigerator freezin up. Thermostat
There should be a clip on the back of the evaporator plate with a bit of foil which normally covers the stat wire end which is the sensor.
Posted on Mar 05, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my refrigerator haier hte21waaww doesn't work, just the frezzer,
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem. 2...Check your thermostat and make sure it is on the colder setting. I hope this helped you, Please rate me...Thanks
Posted on Jan 05, 2010
heatman101
  • 43501 Answers
SOURCE: I have a mini Haier 1.7 refrigerator that wont
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 04, 2010
Why wont it cool?
I would start by checking the compressor relay to see if it's burned up. It's usually attached to the side of the compressor. You need to pull the plug off, then pull it off the compressor. I shake it like checking a light bulb. If you hear loose pieces it's bad.
Dec 27, 2015 | Haier NuCool 2.8 cu ft Compact...
Model hsw02c, 1.8 cuft compressor hums and then i hear a click and it doesnt do anything
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Haier HSW02 Compact Refrigerator
UNIT RUNS BUT WANT COOL BELOW 50 DEGREES... COMPRESSOR IS RUNNING AND COLD LINE COLD ,HIGH PRESSURE LINE HOT BUT WILL NOT COOL BELOW 50 DEGREES.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Haier HSB03 Compact Refrigerator
My Haier HRT02WNC Compact Refrigerator is blowing warm air and will not blow cold on any setting
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 22, 2010 | Haier HRT02WNC Compact Refrigerator
I have a Haier compact refrigerator (Model: HSP03WNWAWN-01, Serial Number: A205673063 - I defrost it and know it will not get cold. It comes on but will not get cold. I tried plugging in in for 24 hours...
Unplug the unit then turn the thermostat all the way on then all the way off, then slowly move from off to fully on position do you notice a spring popping sound at a certain point? Yes No? if yes turn it all the way off and wait ten minutes then plug back on, notice if the compressor comes on or not. If it does then turn the thermostat to half way on does it cool now? if yes you have the problem solved, if not you have an issue with the defrost circuit and you need tools to test it, if you have an ohm meter let me know and I will help you further. Thanks for using fix-ya
Jun 05, 2010 | Haier HSB03 Compact Refrigerator
Haier Model HRT02WNC compact refrigerator not cooling what type of gas does it use?
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
May 16, 2010 | Refrigerators
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Haier HSB03 does not cool, just clicks, when it kicks on.....
Most of the times the problem is the compressor relay that get stuck , try replacing it (no more than $30) , but if the compressor still clicks and won't start probably is burned out.
Oct 15, 2009 | Haier HSB03 Compact Refrigerator
Compact refrigerator stopped cooling. If you turn the thermostat on the light flickers and makes a clicking sound. If you turn the refrigerator off the light stays on. In the back you can hear it ticking...
The clicking sounds like the compressor is trying to start. If the condenser fan running? If it is then you need to check the relay of the compressor. It could be a bad compressor.
Jun 14, 2009 | Refrigerators
Refrigerator mcbr171w
theres not much information about this unit , do you hear the compressor working ? if it does , check the thermostat of this unit , it might be defective.
Apr 17, 2008 | Magic Chef MCBR170 Compact Refrigerator
Haier (B000194UBA) Compact Refrigerator Logo
32 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
