Question about Zanussi 24 in. DE6544 Built-in Dishwasher
Hi, I have a zanussi DE6744S. I can select any program and water fills as normal. The problem is that the cycle runs and runs and dosn't stop unless I turn the machine off. When I restart the machine it just carries on until I press the current program button in for a about 10 seconds and the program stops. On the odd occasion it ends normally on the economy cycle (30 mins) but its pot luck. It does wash as normal but dosn't seem to get past constant washing (no drying) . Hope you can help, Sara
    Top Expert:
  • Zanussi Master
  • 79,865 Answers
The dish washer control panel is defective most likely, have it diagnosed.
Posted on May 19, 2017
  • 883 Answers
SOURCE: machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
Posted on May 30, 2007
  • 22 Answers
SOURCE: zanussi de6855
most probably the pcb unit...had a few of these changed pcb and cured fault, not a job for a novice to be honest, think the parts is about £70-80 from memory.. ally
Posted on Jul 01, 2007
  • 833 Answers
SOURCE: ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Posted on Dec 11, 2007
SOURCE: Zanussi DCE 5655 dish washer
There's a water leak inside, causing the anti[ flood micro switch to activate. Even a couple of tea spoonfuls of water will cause this. Remove the cover and check the polystyrene float at the bottom. A very small amount of water there will cause the problem. Check for any water leaks or even a slight water surge when the machine starts.
Posted on Aug 02, 2009
  • 18 Answers
SOURCE: Stopped Working
The problem is with the PCB, this is the board behind the buttons, you can buy this for £120 or you can get it fixed by QEA for about £45 link below. I am not an engineer but I replaced mine in 10 minutes.
http://www.qualityelectronicrepairs.co.uk/lists/laundrymodels-zanussi_1.html
Posted on Aug 03, 2010
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
Jul 29, 2010 | Zanussi 24 in. DE6744S Free-standing...
Water not heating up
There is a small round solinoid that might have blown its just under the element, you could try this, it cheaper option.
Jun 28, 2010 | Zanussi 24 in. DE6744S Free-standing...
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Zanussi aquacycle 1200 smells coming from between the drum and casing.Suspect it is caused by a build up of slime etc.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Jul 02, 2008 | Zanussi FJS1225W Front Load Washer
Oh No
ANTI-FLOODING CONTROL SYSTEM ALARM [A L 4] Leds [LD9] + [LD10] This control system is operative during the washing phases only, and not in the water fill phases, in which case is it connected to the safety device (see paragraph 7.4.1 ?Water Fill Time-out?).  A float-actioned mechanical sensor positioned on the bottom of the appliance trips a microswitch which is connected in series to the fill solenoid, thus disconnecting the solenoid.  Intervention of the sensor is detected by the electronic control board, which actions the drain pump for 1 minute, after which an alarm condition is generated. Possible causes: a. Water leakage from the tub/sump seal b. Water leakage from the various couplings (motor, OR on the duct to the upper spray arm, etc.) c. Floating sensor jammed mechanically/microswitch faulty
Jul 14, 2007 | Zanussi 24 in. DE6744S Free-standing...
Not Heating
don't replace heater till you have tested continuity across it other items which can cause no heat are module temp sensor
Apr 08, 2007 | Zanussi 24 in. DE6744S Free-standing...
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Too long for a cycle
There are a lot of reasons could cause this issue. Could you provide us more details (if you have) which cycle's stage "takes" this time (filling water, washing process,draining etc... ) You answer will allow us to direct you the solution. Good luck !
Jun 27, 2006 | Zanussi 24 in. DE6744S Free-standing...
Zanussi 24 in. DE6544 Built-in Dishwasher Logo
115 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
