Hi I own a SONIQ QSP426Tv2 Plasma tv. I was lving in Australia and decided to buy one.. a year later i moved to New Zealand and it wont give me acces to change the country to be able to pick up digital or analog tv.. any solutions would be appreciated as im finding nothing.
  • 15 Answers
SOURCE: SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
Posted on Dec 30, 2007
  • 4234 Answers
SOURCE: analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Posted on Sep 23, 2008
rapanSF
  • 150 Answers
SOURCE: 42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Posted on Nov 17, 2008
  • 362 Answers
SOURCE: Not picking up Digital signal from box but can receive it analog
So many factors could be affecting your reception. Keep in mind that the digital signal is all or nothing, either you have a signal or you don't, with the regular signal you can pull in weak signals but you can't with digital. Your converter box when turned on will probably not pick up the standard signal. The distance from the digital signal and the direction the antenna is facing also will affect your signal.
Ok with that said you will have to clear the path between the broadcast signal and your antenna, I know this will be a chore but take your antanna out of the attic and put it outside as a test only, this dosnt mean you cant have it in the attic it will just be a signal test.
Once the antenna is moved, from the menu scan for channels and see what you get. Let me know and I can help further.
lone99star
Posted on Jan 09, 2009
SOURCE: Hyundai 42" Plasma TV
hyundai hpt2450 tv switches on with standby button on remote or at tv and picture and sound ok but the little "tv" symbol at bottom of screen remains on locked in tv mode.It is not possible to change channels alter volume or change input source! The set does not respond to the remote or on board controls.It cannot be switched back to stanby with either the remote or the sets own standby button. It has to be switched off the the main on/off switch.
Any suggestions?
Posted on Jan 10, 2009
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
My Soniq 42inch plasma TV model no.QSP426TV2 makes
Is the clicking through the speakers or from the back of the TV? Do you get a picture and sound? It might be something that is warming up and expanding as it would normally if this is the case
Oct 07, 2014 | Televison & Video
I have a soniq 42" hd plasma idtv model no: qsp426tv2 and need a code for the one for all remote control
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 04, 2014 | One For All Televison & Video
I have a Soniq 50inch plasma, the picture has turned very red. It has happened in the past, normaly I just turn it off for a few minutes and it goes away, but it has been 2 days now and it hasn't
plama tvs do this often after you have it for a while. there is no salution but to buy a new tv. this happened to my dad's friend and he said you cant fix it you just have to buy a new one. he akso said his next tv wont be a plasma of ant type!
Jun 05, 2012 | Televison & Video
Hi, i bought this dvd player in australia and have since moved to new zealand. will all the tv features work?
The DVD player will play Region 4 DVDs both in New Zealand and Australia. If this player has a TV tuner, then the stations may need to be set/scanned for NZ stations.
Sep 29, 2010 | Computers & Internet
I used my iphone in australia then moved to new
I fear you cannot do that, without an actual "Jail Broken" iPhone.and or a Telecom NZ suitable phone.
Jun 08, 2010 | Apple iPhone 3G
Soniq 42'' QSP424T keeps freezing
I have been repairing Plasma Tvs for some 3 years now and have found most of the problems caused are by Capacitors.Once again Soniq are no different to the others.The fault is on the main Video Control Pcb.Replace Capacitor C529 which is a 470mfd25v.This cap is mounted next to an inductor coil at the top middle of the pcb.This Pcb is the one which has the tuner and all inputs on it.
Good Luck AND PASS THE WORD AROUND. LET US KEEP THE SERVICE INDUSTRY GOING.
VIEWCLEAR VISION PL BRISBANE AUSTRALIA.
Feb 16, 2010 | Televison & Video
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
