Question about LG Washing Machines
LG front loader get stuck intermittently at 22 and 9 minutes
  • eric bosman
    eric bosman May 11, 2010
    please let me know modelnumber
  • 487 Answers
Normally it will be the timer
Posted on Aug 15, 2008
My lg front loader washing machine is getting stuck on the last 10 minutes of a cycle and has flashes of blue lights or sparks coming out from the underneath. What could be the problem with this?
blue lights and sparks indicate a serious electrical problem
call an electrician immediately and isolate the machine until it is fully inspected and pronounced safe
water , power and people do not mix
once you have determined the problem then get a quote to fix ir replace the unit
Aug 18, 2016 | LG F12C3QD White 600 mm Washer Front...
My LG front loader washer making noise in spin cycle, especially last 5 minutes, how to I fix this?
open door and see if the drum can be moved up and down or side to side a lot. if it can, then you need a new bearing most likely. this would most likely only happen on a older washer that has been used quite a bit. repairclinic.com and appliancepartspros.com both have very good videos to show how the bearing can be replaced. takes some time and work, but if everything else on the washer is good, it could be worth the trouble. good luck.
Jul 11, 2015 | LG WM Washing Machines
Lg front wont finish wash resets to spin cycle
Sounds like the programme software control logic circuits are playing up. This is a job for a qualified Technician only. The control board may need replacing.
Pay for a service call and just get a quote to fix it.
If it's within your budget, fix it oherwise replace with another machine of your choice of brand and features.
Poppa
http://www.cdbaby.com/cd/poppamadison
Apr 06, 2013 | LG WM2277H Front Load Washer
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
My LG tromm wm2277hw front loader just turned off, can it be a switch, there's power in the outlet, no lights, circuit board is off, no water underneath, dryer is ok plugged in the same outlet,
That could very well be the line voltage suppressor (called a noise filter) that is built into the washer. Take the top off and follow the power cord into the machine. It connects to this component. themobilian_17.png
PAGE 22
Feb 06, 2011 | LG WM-2277HW Front Load Washer
I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
LG 42PC3D-UD plasma tv takes 22 minutes to turn on
the more i think about it, replace your power supply first. they have been known to cause this problem you are having
Feb 27, 2009 | LG 42PC3D 42 in. Plasma Television
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Sep 11, 2008 | Washing Machines
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Washing Machines Logo
168 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
