*******All of your data WILL be lost during this process so back everything up first**********
1. Power on the machine.
2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts.
3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.).
4. Click "OK" to continue.
5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit.
OR
1. Reboot, and press F8.
2. Select Repair.
3. Select Reinstall Windows and follow prompts.
OR
Running System Recovery from Windows
1. Click Start>All Programs>Acer Empowering Technology.
2. Select Acer eRecovery Management.
3. Select Restore (bottom of eRecovery screen).
4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.).
5. Select Yes then Next, the system will reboot and start the recovery.
Reboot or Recover? If you have a Factory Recovery Partition, use this procedure, a Recovery will return your Laptop to the day it came out of the box, YOU WILL LOSE ALL YOUR DATA, and you must install ALL Windows, Acer updates and software you installed, a Restore will return to a date selected, if your Laptop has Restore enabled in software. Acer Restore/Recovery Procedure: http://panam.acer.com/acerpanam/desktop/0000/acer/aspiree360/aspiree360faq40.shtml
Try a system recovery, if it has a recovery partition. Remove any madia,DVD, CD, USB, etc. Unplug, remove battery, plug in, push the on/off button, immediately prees and hold the ALT+F-10 if that doesn't work, reboot and use F-10, to load the restore/recovery software, do a factory recovery to return to factory settings. You may want to write down the password and put in a safe location, or put your user name with a administartor password to override.
How do a restore my acer laptop to factorysettings. Turn off your laptop. When you see the Acer screen, press Alt F10. This should take you to the recovery partition on the hard drive. From there, you can do a factory restore.
Acer Aspire eRecovery
The Acer Aspire eRecovery tool comes in both a DOS and a Windows
version with the Windows version offering more features. To open the DOS
version, boot up your computer and press the Alt + F10 key combination
when you see the Acer splash screen. To open the Windows version, allow Windows to load and then open Acer eManager followed by double-clicking the eRecovery link.
Using the eRecovery tool is fairly simple once you have it launched.
You can either restore your Acer Aspire to factory settings from the
hidden partition or with the recovery CDs. Once eRecovery loads, you may
be prompted to enter a password. According to Acer, the default
password is: 000000. If you have not changed the password, enter these
six zeros when prompted.
Acer usually preinstall its recover.. so try start, programs, acer recovery or carbonite or any other recover you see, follow the instructions and it will do the rest!
You can launch the recovery option by pressing 'F10' on startup, or if that fails, you can do a system recovery from the ACER EManagement 'Backup and Restore' option in Windows itself.
Recover to original state using Acer eRecovery Managemet tool.
press alt+F10 during boot-up process. This opens eReovery main page. unless you have changed it, the password is six zeros (0s). Click recovery actions. Select RESTORE FACTORY DEFAULT IMAGE. Once you've confirmed that you wish to proceed the computer will reboot and start to restore the system from the image contained in the HIDDEN PARTITION on the hard drive.
If you have Recovery CD's you can use that to recovery your computer for factory settings. If you do not have recovery Discs and Have not made any changes to the partition of the HDD since you purchased it try the following.
Turn off the device Turn on by pressing the power button Press Alt on the keyboard and keep tapping the F10 key immediately when you see the Acer logo. It will bring you to the Recovery screen and you just need to follow the instructions on the screen to complete the recovery.
Please do not forget for rate this solution with your comments if you find it helpful
I have a feeling you will have contact www.acer.com for them to reset the emanager password for you.
Have you tried to restore this unit,
It shouldn't be passworded either just reset back to original install.
