Question about Volkswagen Car Audio & Video
Hi I am trying to get a Iphone 3GS to play through my daughters RCD 310 radio in her VW Caddy van. The van is Jan 2010 but she has only had it for 10 months. There is a Iphone connection coming up close to the gear leaver, it is connected to a box underneath which is a VW 000 051 444k interface. Before she bought the Iphone 3GS she borrowed my Ipod Touch and it seemed to work through this connection. But the Iphone 3GS will not. I contacted a supplier of retro fit interfaces, who suggested I get a device to reduce the voltage from 12v to 5v. I got the device and now she can get the 3GS to charge through this connection. I am considering buying a retro fit interface which claim to work a 3GS through the CD changer connection of the radio, but don't want to spent 50 to 60 pounds, only to discover they are no better than the existing VW interface already installed. can anyone suggest how to get the Iphone to work through the radio. Regards Jim
  • jimannie May 21, 2011
    Hi Mark
    Many thanks for your prompt reply. I already have a small device I have bought to convert the voltage to the 5v supply, and this is enabling the Iphone to charge. But why, with this device fitted will the existing VW 000 051 444K interface unit that is already fitted in the vehicle not work?
    Regards Jim
  • jimannie May 22, 2011
    Hi Mark
    Thanks for getting back again, We have decided to go for a new interface and see if it works. Mainly on your advice, thanks. I will let you know how we get on. The other reason I have decided to go for a new Ipod interface is that I see there is a market for the secondhand VW 000 015 444K interface on eBay. What really crunched it and we decided to go for a new one was when I Googled in the VW interface No and on an old eBay page, item No 170625522118 there is a second hand VW interface for sale, on the bottom of the advert it states that this interface will not work with the newer VW RCD 310 radio.
    I have also been looking up on Youtube how to remove a RCD 310/510 from a VW and I am glad I did, as it is a little more complicated than I expected, although not impossible.
    Regards Jim
    Link to old eBay Advet
  • 776 Answers
The first generation iPod Touch and previous iPods had one pin that allowed the device to charge from 12 volts (firewire connection) and another pin to allow it to charge from USB (5 volts). Various companies used these pins to allow charging from 12 volt vehicle voltage to the firewire pin. Those manufactures did not connect anything to the apple 5 volt pin since the iPod could decide which voltage was available and use which ever was avaialble.
Unfortunately, Apple decided to not support using the 12 volt pin on newer device (yet they still use the same connector - the 12Volt pin just doesn't connect to anything inside the device (iPod or iPhone). Those device (chargers) did not have anything connected to the 5-volt pin.
If you buy the retrofit interface, it will work. They simply convert the 12 volt from the car, put it to a 5 volt regulator and route it to the 5 volt pin on the Apple connector. You should have no troubles.
-Mark
Posted on May 21, 2011
  • Mark T
    Mark T May 22, 2011
    Jim,
    The VW unit was designed for the original iPods and the iPods must have the ability to charge with a 12V input. Apple stopped supporting the 12V input pin on all newer devices (after Aug 2009 approximately). Your device VW 000 051 444K only has 12V pin active (with no 5V pin active).
    All older devices have this problem, iHOME speaker systems and iPod docks for many car models. That is why companies started making the little adapter you were able to buy.
I have a 2006 vw caddy .. Radio will play for few seconds then makes a boom noise and shuts off
WHEN THE RADIO WORKS THE SOUND IS OK OR DISTORTED?WHAT IS YOUR RADIO TYPE?DOES IT GET ON AFTER A FEW MINUTES?
Jan 04, 2015 | 2006 Volkswagen Caddy 1.9
Vw rcd 500 power is showing
if im not mistaken they run off the cars on board computer to display (CLOCK & TEMP) on the center console?
so if im right, have you check the fuse in the fuse box down beside your feet under the steering column. trust me don't check the radio fuse.....check them ALL! as it runs off the interior light fuse as well. start with the 20A ones.
if im wrong, then you've popped the fuse on the back or inside the head unit...
Feb 12, 2014 | Onkyo Audio Players & Recorders
Wire diagram vw caddy van for stereo
As you have power to the eject and cd, it would seem to be a problem with the Power switch on the head unit.
Jul 14, 2013 | Vehicle Parts & Accessories
Had problems with vw caddy van starting when warm,...
2004 vw 2000sdi caddy van wont start some mornings you need to wind it over before it fires, immediately after it fires you can switch off ignition and it will start first time and continue to start all day. vw dealer says no fault codes present. gloplugs renewed, new battery,fuel problem? Has anyone come accross similar problem I
May 20, 2010 | Cars & Trucks
How do you take the radio out of a 06 VW CADDY Tdi??i have a 7'' touch screen to put in instead of the old radio but dont know how to remove the old radio,its not in the users manual so if anybody can...
Hi, Pull/take off the outer bevel edging, pull at each side in the side area so you dont snap it. then get 4 mini screw drivers, if you don't have a stereo removing tool, put one in each of the 4 holes and then hold them all at once and push outwards to push the springs inwards, then pull forward with a bit of strength and it should come with you.... enjoy
Thanks Mark
May 03, 2010 | Volkswagen PAC C2R-VW Radio Replacement...
How do i remove the radio on a 08 vw caddy panel van. I need to fit a parrot handsfree kit.many thanks
the trim just pulls off start at the bottom and work your way up, the radio is then secured in by 4 torque heads
Aug 12, 2009 | Volkswagen PAC C2R-VW Radio Replacement...
VW Radio unlock code
i need to find the code to get my radio off of safe mode for a 1998 volkwagen golf?
Jun 24, 2008 | Car Audio & Video
Car Audio & Video Logo
339 people viewed this question
Top Volkswagen Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Jose Velazquez
Jose Velazquez
Are you a Volkswagen Car Audio and Video Expert? Answer questions, earn points and help others
