Question about Ovens
My belling xou60f oven amber temperature indicator light stays on when oven has been switched off.
  • Sue Dwyer Dec 04, 2012
    Hi can you tell me where the fuse/circuit breaker is on the cooker as I cannot find it anywhere Thanks
4 Suggested Answers
  • 417 Answers
SOURCE: Faulty Oven
Have you tried www.appliance-parts.co.uk, they have a useful parts finder service.
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Posted on Dec 13, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
Belling cookcenter oven over heats and light stays on
It sounds like the people who changed the elements did not connect them to the correct wires. The thermostat seems to have no effect on the elements, and the light switch seems to have no effect on the light, explain this to them and that you think they fitted the elements directly onto the power input to the device, instead of the correct connections.
Dec 14, 2013 | Ovens
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
Vulcan Comenda VC200 Wiring Diagram Series: 200/31/0166
Hi i have a belling DF951 fan oven .the heater element stays on when the oven is switch off .Is it the thermostat that is faulty because i can not leave it on .I HAVE TO SWITCH THE MAIN SUPPLY OFF.Or the oven stays on all night
Aug 23, 2013 | Belling XOU174 Electric Single Oven
I replaced the element in my belling double oven, it wored for a while but was very hot thought it was the thermostat, now it has no heat at all no light but the fan still works.The top oven and gril has...
Hi.
Replace the temperature probe located in the oven cavity. The probe was initially shorted. That caused temperature runaway with the oven getting too hot. After a while the shorted sensor blew completely staying open all the time. That is resulting in no heat.
If the temperature sensor has already been replaced, then problem is either wiring or oven electronic control. Wiring harness is tested checking continuity between different points.
Regards.
Ginko
Jul 17, 2011 | Belling XOU592 / XOU593 Electric Double...
The oven does not cook the food, it only warms the food.
Two possible problems. If the oven has two or more elements for normal operation then one of these elements may be faulty. The thermostat may also be faulty and only heating to a far lesser temperature than required. The way to tell is turn the oven to a normal cooking temperature.
If the oven indicator light stays on all the time and doesn't cycle off then it may be an element problem, meaning that the oven can't reach the temperature setting desired.
If the oven indicator light goes off after a while and then cycles on and off then the thermostat is working correctly but the temperature may not be hot enough. You may have to purchase a small oven thermometer and check the oven temperature against the thermometer to get a better idea of what the problem is.
Feb 10, 2011 | Viking Ovens
Orange temperature light stays on when oven is switched off
For this to happen, indicates a faulty thermostat that controls the oven temp, I would fit a new one
Mar 03, 2010 | Baumatic Ovens
Fan oven wont heat up
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
FAN OVEN DOES NOT WORK
most common fault is that the ring element has blown. fairly straight forward repair for an expert.
Mar 12, 2009 | Ovens
Faulty Oven
Nov 30, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
