Question about Panasonic Microwave Ovens
Panasonic NNA722 Microwave Oven The microwave function is working. I think the thermostat on the convection oven is broken as it burns all food. Is this a home repair?
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
Thanks for this. Thats exactly what I did. It didn't work at first, however, I think it was my impatience! After selecting the Microwave, you MUST wait until you are told via the screen to input the time. It now works fine. Thanks again. Just needed perseverance! Mike
Posted on Aug 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
WhIzAtIt
  • 136 Answers
SOURCE: Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Posted on Sep 24, 2008
Sailorm0on
  • 61 Answers
SOURCE: Rust inside the microwave oven
This is just okay but if you're quite doubtful you may bring this to any appliance service center for repaint
Posted on May 15, 2009
  • 178 Answers
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Posted on Sep 14, 2009
My Kenmore Microwave slowly heats but mostly the dishes vs. the food. By the time the food is warm enough, the plate or mug is practically baking. The microwave is only 4 years old, so I can&#39
Sounds like you don't have proper microwave-compatible plates or mugs. Must have lead in them, or in the paint (!?!) Try a plastic plate or even a paper plate. I can't think of anything that would make the microwave oven do that, UNLESS it's a microwave/convection oven, in which case, the convection heater must be coming on whenever you are trying to just use the microwave function.
Sep 24, 2014 | Kenmore Microwave Ovens
After many years of good service my Dimension 4 does not microwave. It goes through all the motions but doens not heat the food. the convection and grill functions are working fine. HELP!
Hi Michael,
i think something wrong with its high-tension circuit or your magnitron is bad.
the minor fault is open of therm stat for protection.
or burnt fuse in circuit.
regards,
nuwan.
Jan 09, 2014 | Panasonic NN-T888S Convection/Microwave...
Glass turntable broken
microwave should work with out the plate as the plate turning the food is for cooking evenly for warming porpuses there should be no problem
Oct 19, 2013 | Panasonic NN-T888S Convection/Microwave...
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
10_2_2012_12_41_44_pm.jpg10_2_2012_12_42_15_pm.gif10_2_2012_12_42_35_pm.gif10_2_2012_12_43_09_pm.jpg
Oct 01, 2012 | Panasonic NN-C994S Convection/Microwave...
Not heating the food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 15, 2011 | Panasonic NN-V671S Convection Microwave...
I have a sharp over the range convection microwave modelr-1874F The convection works but the microwave sounds like it working, the turntable turns but it does not heat the food we tried unplugging it for...
Every time the microwave part of an oven do not heat it normaly means a faulty MAGNETRON (the device that produces microwves) unfortunately if it's the magnetron they are allmost as expensive as the oven it self, you could allways check for a burned fuse, (allways be prudent opening an applyance)
Jan 04, 2011 | Sharp R-1874 Convection/Microwave Oven
On microwave mode the oven makes light buzzing noise and does not heat food. Convection oven and grill functions work perfectly. michaelchrys@yahoo.com
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 17, 2010 | Panasonic NN-A811A Convection/Microwave...
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
Microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
42 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
