How much r22 charg in 1 ton split ac unit - Heating & Cooling
    Guru:
  • 683 Answers
What your asking is impossible to answer. True the charge goes up with the btu size but there is no set amount. To figure this out you need a couple of things.
1. On the condensor (outside unit) has a lable that will tell you how much R-22 the condensor will hold.
2. On the evaporator (inside) should also be a tag that will tell you how much the evaporator will hold.
3.Then you have to know the line sizes and also length to tell you how much refrigerant the line set will hold.
You add all these up and you will have the correct amount.
Hope that this helps.
Posted on May 21, 2011
  • Matt Heinz
    Matt Heinz May 27, 2011
    The best way to charge your a/c is going to be on a 80 degree day charge unit slowly until the unit sweats back on the suction line the one with black insulation on it. Charge unit till the unit sweats back to the compressor till there is a ring of sweat on compressor the size of a half dollar.
  • Walter Kunesky
    Walter Kunesky May 28, 2011
    Lets play a game of what if with you.
    WHAT IF:
    drier is semi clogged?
    a-coil is dirty?
    blower wheel is dirty?
    registers are closed in the system?
    ductwork is the wrong size?
    filter is clogged?
    blower motor fan is not up to par?
    condensor is dirty?
    metering device is not feeding properly?
    You have to take all these things into consideration and you didnt ask any of these questions? I know you are new to the field so before answering questions that could be wrong, remember to ask yourself, "WHAT IF" Rememer I helped you when you didnt know how to check the valves on a compressor, they would have taught you this in school.
Whatis ideal r22 gas pressure required in 1 ton split ac of BlueStar.
Doesn't matter how big the unit is, pressures remain the same. On a satisfied temperature, approximately 75 degrees, r22 should be around 65 psi. The hotter the house, the higher the pressure. Head pressure varies on outdoor temperature. 90 degrees outdoor temp, approximately 200 to 225 psi on high side.
Jun 05, 2017 | Heating & Cooling
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
How many pounds of R22 is requried in 7.5 ton or 15 Ton AC unit.
it all depends on how long the lines from the compressor to the evaporator are the label on the condenser unit should give you a ball park figure
Jun 01, 2011 | Refrigerators
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
Heating & Cooling Logo
812 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
