Question about Furuno GP7000 / Nt Gps/Waas Plotter
I have GP 7000 F, when I power up the plotter tests come up OK but the sounder just comes with sounder initializing...... Please help I would love to go fishing..... Thank you
  • 794 Answers
Hi markm263,
Have you already tried resetting the system? This can help you address the issue however, doing it will delete all tracks, waypoints and routes and all default menu settings are restored. If you are willing to restore the system to default settings here's how:
1. Turn the power on while holding the [CLEAR] key down.
2. Release the [CLEAR] key when you hear the beep.
3. Rotate the [ENTER] knob to choose "RAM menu" and then push the [ENTER] knob.
4. Rotate the [ENTER] knob to choose "RAM clear" and then push the [ENTER] knob.
The message "Are you sure?" appears.
5. Push the [ENTER] knob to clean the memory.
The equipment restarts automatically.
Hope it helps.
Thank you for using FixYa.
Posted on May 21, 2011
GP Furuno 7000 sounder not powering up
Be sure to check your input DC voltage all the way to the unit itself. The intermittent condition you described sounds like a bad connection outside of the unit itself. Once you confirm that you have good 12 or 24vdc input to the plotter and it still won't power on, there is an internal 4amp fuse you can check. Proceed with caution if you decide to open the unit yourself.
Nov 12, 2013 | Boating
My hp designjet 500 doesn't recognize the I/O Card
By I/O card I assume you are referring to your JetDirect or the optional HP/GL2 formatter board, your EIO devices?
If you have them installed and the plotter does not recognize them.
Shut down the plotter then remove the power cord from the plotter or the wall and wait 5 mins.
Remove ALL EIO devices (JetDirect / formatter).
Plug the plotter back in and restart the plotter.
Test functions of the plotter.
Shut down the plotter and then add back only the JetDirect.
Start the plotter and check the function, and check if the menu will allow you to setup the JetDirect.
If successful, shutdown again and reinstall the Formatter Card (if you use one).
Test functions and check the I/O setup in the menu.
The idea in a nutshell, remove the cards and add them back one at a time to see which one if any is bad and causing the I/O to shut off.
If this does not help, you may need to replace the plotters Electronics module
Aug 16, 2012 | HP DesignJet 500 InkJet Printer
Tried upgrading Canon iPF710 firmware from 1.35 to 1.40 on 2 separate plotters and received a !Error E196-4040 Call for service message. Plotter will not come to a Online status.
Power off and unplug the printer for several minutes. On power on the printer had the same "ERROR E196-4040 Call For Service" after Initialization. Next start the printer in Service Mode, turn on the printer while holding down the [Paper Source/Feeder Selection] button and [Information] button until Initializing appeared in the display. An "S" will appear in the upper right of the version display. Power down and do a normal Power On and the printer should do a normal initialization and came On Line.
May 28, 2011 | Canon imagePROGRAF IPF710 Printer
System error on plotter screen
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Jul 06, 2010 | HP DesignJet 1050c plus InkJet Printer
When I turn on the unit it will not read the depth only a blue screen and it will not let me switch out of auto mode or run the sounder test?
I know this is an old question but just ran across it. The 1833C/NT is a radar and chart plotter. It requires the external and optional black box sounder to have depth recorder functionality.
Oct 03, 2009 | Furuno 1833C/NT GPS Receiver
GPS/plotter/sounder will turn on and operate properly. Unit will
Try removing your chart card then powering up your unit. Chances are your chart could be bad and is causing the problem.
Jun 08, 2009 | Furuno GP1850DF GPS Receiver
Older HUMMINGBIRD DEPTH SOUNDER LCR-3D . WAS WORKING FINE WHEN I PUT IT AWAY, NOW WONT POWER UP. HAVE CHECKED THE INPUT POWER AND IT IS OKAY. I DO NOT SEE A FUSE IN THE UNIT. ITEM IS OLDER UNIT BUT IS...
We have an old Hummingbird Depth Sounder (Wide 100, 94 model) and it turns on but must be on test mode or smething cause we can not get it off. Does anyone know or have a manual to solve this problem. Please help.
Aug 07, 2008 | Hummingbird GPS
Furuno GP7000 / Nt Gps/Waas Plotter Logo
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Furuno Boating Expert? Answer questions, earn points and help others
