Question about Microwave Ovens
MY microwave model number Panasonic NN T764SF was operating fine unitl now. but all of sudden the door just would not lock and the light is on all the time. i tried everythng but the door just is not locking. its also not that the button is stuck nothing lie that . hence now my microwave doesnot work because i can not lock the door. please help
  • Microwave Ovens Master
  • 9,086 Answers
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can order Panasonic parts here.
If you prefer, you can contact your nearest Panasonic-authorized servicer.
Posted on Aug 18, 2008
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
Trying to locate door latch part but Panasonic website not recognizing NN model number.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
Apr 28, 2013 | Microwave Ovens
I need a manual for the panasonic NN-CT562MBPQ
The manual can be downloaded here:
http://www.panasonic.eu/Downloads/en_GB/popup.html
Put in the model number with no spaces: NNCT552W and take the one marked "Operating Instructions".
Feb 26, 2013 | Panasonic Nn-Ct562mbpq Combination...
Light nn-sa651s
Panasonic FAQ:
The microwave oven model NNSA651S was manufactured in a way that the oven light turns on only while cooking. - FT
Stupid design!!
Feb 19, 2013 | Panasonic NN-S541 Microwave Oven
Panasonic microwave nn-6372awm memory codes
I HAVE A PANASONIC MICROWAVE,MODEL NN-6372AWM,SOMEONE WAS GOING TO USE IT AND I DON'T KNOW WHAT THEY PUNCHED,BUT IT NOW SAYS LOCK ON THE SCREEN,THE DOOR WILL OPEN BUT YOU CANNOT USE THE TIMER.HAVE HAD IT ABOUT 10 YEARS,WORKS FINE,LOST THE BOOK ON IT.CAN ANYONE TELL ME HOW TO UNLOCK IT.I AM SURE IT HAS A CODE.
Apr 21, 2010 | Panasonic Microwave Ovens
Our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Mar 27, 2009 | Panasonic NN-S252WF Microwave Oven
Inside light is burned out.
The Sears parts Web site has a ton of helpful info on this model, including disassrembly help. Looks like a lot of the actual service manual online! You can also order parts there. Enter your whole model number NN-S567BAS at http://www3.sears.com/ (the 3 is correct) Terrific!
Dec 26, 2006 | Panasonic NN-S567BA/WA/LA Microwave Oven
Microwave Ovens Logo
198 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
