Question about Hoover U6311-930 Power Drive Bagged Upright Vacuum
Hoover windtunnel powerdrive w/bag
Brush roller belt broke and all replacements are too large. I've bought 2 belts,both hoover,correct number,and they don't work.
There seems to be a little plastic wheel like thing in the way. The wheel thing will move, like it's on a spring.Can you help?what am I doing wrong?
  • 876 Answers
I am wondering if you have purchased the correct belt- there are two belts on your machine. Go to this site and have a look at the belts there. Also, if youno longer have your manual you can download one from this site with your MODEL # and it should have instructions on installing the correct belt. Good luck to you.
Posted on Aug 15, 2008
    Master:
  • 521 Answers
Its the gear.and the belt has to be fitted on the gears properly.
  • 3 more comments
  • tech expert12 Aug 15, 2008
    if the belt is not properly fitted onit only the gear will move the belt is to control the speed of gear and run the unit.so fit it properly.its simple.
    the gear will continue moving till the belt is not attached properly on it.
    just ease out one end to put the band round on that gear(which you call wheel) Not so easy getting it back, and this is the only way of putting it all back together as it was before.
    how to change the belt the procedure as follows.check this
    Take off the bottom plate, also remove the screwsfrom the bottom to remove the top cover, also there is a screw under the Hoover emblem on the top cover, with these removed you can get to to brush roll and belt.
    pls do rate the solution if it helps you to solve your problem sir .keep me updated for any further sugestions.
Belt broke, there are 2 belts the wider one broke & I can not get it on. The thin belt I got on OK. What do I do?
Greetings,
We have recorded a ver convenient video on how to replace the belts on your Hoover Windtunnel Self-Propelled Upright Vacuum Cleaner. We also explain how to do regular maintenance on the roller brush to prolong the life of these belts. It's best to replace both the thin belt, and the fat belt, Parts 38528034 and 38528035 at the same time.
Here's our video repair;
I hope that this helped you. If this helped, please be sure to rate the repair as helpful by clicking on the Thumbs Up Icon in the repair.
Thank you very much,
Chris Jones
GoVacuum
Mar 22, 2010 | Hoover U6434-900 Bagged Upright Vacuum
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Hoover WindTunnel Self-Propelled V Belt
when you released the end to slide the new belt on it allows the tension roller to slide into the wrong position. Remove the top so that you can see the roller, at the left side of the roller mechanism there is a screw, loosen it enough to allow the roller to return to the correct position.
good luck
Mar 23, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Replaced the belts on Hoover WindTunnel U6473-900/brush won't tur
There is a belt tensioner that maybe not contacting the belt when you tilt the handle back, It is either jammed and not moving up and down freely or it is broke. Look down below the belt, there should be a small wheel, that has to contact the belt.
Dec 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush won't spin
Yes it could be the belt or the "Bearing Assembly". I had the same problem with a vacuum I got from a friend. 1st I replace the belt,but when I turned the vacuum on I could smell something burning and then the belt broke in half. I then realized the brush roller was stuck in place and would not turn even with force applied. I later found out that 1 of the 2 Bearing Assembly's was worn out,when a Bearing Assembly is worn out the brush roller can not spin. So now it looks like I need to buy a whole new brush roller,unless I can find a place that sells the Bearing Assembly for part number 61445-1,which is a roller brush for a GE Wal Mart vacuum.
Dec 08, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel U6439900
please go to the hoover vac store using the following link. you will have your exploded diagram for the machine and any spare parts you might need. http://www.thehooverstore.com/U6425.html
Sep 15, 2007 | Hoover U6630-900 WindTunnel Bagless...
Hoover U6311-930 Power Drive Bagged Upright Vacuum Logo
146 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
