Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
I have a red and blue shadow in my picture
There is a red and blue shadow in my picture and have tried to fix the convergance, but it shows my blue is alligned and the red just won't allign. Some of the allignment lines are actually slanted. No matter what I try I can't seem to line them up, I can't even get them close! What do I do? i have a akai 55 inch rear projection tv , and the picture has bluish ghost like image on everything, its model #pt5598 hd, im being told its the convergance motor, and repairs would cost between 225 and 300 dollars, is this legit, or is it something i could fix myself ? thanks
  • Anonymous Oct 19, 2008
    Where is the coil located so I can try your solution?
  • Anonymous Nov 14, 2008
    red alignment is off and ghost like shadows
    Sergeant:
    Champion:
  • 258 Answers
IT sounds like it needs to be degaused.
Before checking this, check for speakers placed by the set. this will cause it too.
The best way to avoid this situation is
  1. Don't place unshielded speakers near the set.
  2. Don't move the set while it is turned on.
The coil that is used is about $50 and can sometimes be found at industrial electronics stores. It's called a degausing coil. most TVs have a version of this built in and mutiple power on/off/ons may fix it, but don't hold your breath...
The trick is to turn the coil on with it right up to the screen. Move the coil in a big circular motion parallel to the screen as you S-L-O-W-L-Y move away from the screen. when you are as far away as you can get [about ten feet] turn the coil off. Caution. KEEP HARD DRIVES, CREDIT CARDS, AND FLOPPY DRIVES AWAY from the energized coil!
Good luck
Ken
Posted on Aug 15, 2008
Tv shows images in red, blue and yellow colors only
Tv have a problems known as a convergence picture problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead.This tv convergence board must be repairs,u must require to replaced components parts like 2 STK convergence ICS and some or all of it resistors too.To fixed the the tv convergence board to solved the tv convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Jun 29, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My picture was fine until i tried adjusting red and blue dynamics now i got the shadows in picture. how do i adjust it back.
Your convergence has failed and need to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed.
You can get the parts and instructions from www.TvRepairKits.com
Apr 24, 2011 | Hitachi 50UX58K 50" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue/yellow shadows
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
How do i get a crystal clear picture on this set?
Your tv is experiencing convergence problem. if you have tried the perfect focus adjustment from the menu and still not fixed, then the convergence ics need to be replaced. these ics converge the blue and red beams with the green to give a clear picture.
Hope this helps
please rate me!
Mar 19, 2009 | Philips 9P5034C 50" Rear Projection...
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Red double picture with green and blue
convergence problem there are 2 integrated circuits inside the set needs to be replaced
Aug 25, 2008 | Toshiba TZ50V51 50" Rear Projection...
well i think its an circuit prob if theres any circuit break on the pcb panel or panel connector would b loose
Aug 24, 2007 | Akai PT4298HD Rear Projection Television
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
