What do the codes mean on the remote contoller for 3PRM801 dbo
Hello, I need a remote code for my Citizen DVCD668 to work with my RCA RCU404R universal remote contol. Thanks in advance!
Use code search on your RCA remote to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Aug 07, 2016 | RCA Televison & Video
Conrol codes for a Lexibook Remote control type ST600
Universal remote control code for Harman/Kardon TV only = 0054
Universal remote control code for Harman/Kardon VCR, DVD and other devices= 0081, 0038
Try the second ones, they are supposed to work with your device.
Regards
Mar 11, 2008 | Audio Players & Recorders
How to get code for remote contol
To which device do you want setup codes? Waht is the brand name of the Remote control you have?
May 12, 2012 | Universal Remote Control GAMER Remote...
Contol Samsung Blu Ray BD-P1600 with Samsung remote
Compare the manufacturing dates and if remote is older, it is normal. If not, ask Samsung. Good chance
Oct 02, 2009 | Samsung BD-P1600 Blu-ray Disc Player
Need the remote contol code for AOC L26W861 Lcd TV
Just kept repeating the U-Vesre procedure over and over and Wham! Persistance was the key.
THX
Jun 12, 2009 | Televison & Video
I need the code for a Philips SRU3006WM/17
Codes listed for Sony DVD players are 0300,0400,0500,0541,0200,0540. Hope this helps due to no listing for Blu-Ray players.
Mar 29, 2009 | Universal Remote Control 6-Device...
Hi I carn't set up my total contol remote for my tv can you help
Hi fishbones675,
Not a problem - here's how to do it:
1) Turn on your TV.
2) On your Total Control Remote, press and release the TV button.
3) Press and *hold* the SET button (the red light will blink once - keep holding it - it will then blink twice - release the button).
4) Enter the four digit code for your TV (the red light will hen blink twice).
5) Press POWER - the TV should turn off. This will mean that the remote has successfully been programmed.
If you don't know the code for your TV, refer to the list of codes in the user manual, available at the following web address:
http://www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
If your TV brand is not on the list, or if the codes for your brand don't work (which I've only seen happen once), then try the CODE SEARCH feature:
1) Press TV.
2) Press and hold SET (as above)
3) Press 9-9-1.
4) Alternate between pressing the TV and POWER buttons. When your TV turns off, that means the remote has found a code that will operate your TV.
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Televison & Video
Remote code
I own a One-for-All universal remote, and my booklet says the setup code for a Haier TV ( without a built-in DVD or VCR) is 1034. I can not guarantee this number will work with your remote, but it is worth a try.
Jun 27, 2008 | Televison & Video
Codes for philips remote contol pm 625s
here are the codes, it's a pm 725,but the codes for phillips are standard for their brand and they should work.
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM725.pdf
Feb 24, 2008 | Philips PM625 Remote Control
CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Jan 30, 2008 | Televison & Video
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
