Question about Panasonic CQ-VD7003U Car DVD Player
Need to know which set of rca jacks to hook my amp to. when i hook up to rear it act as rear speakers and the same thing to front. when i hook it up to av out it doesnt work with the volume it stays on and cant adjust it. help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
  • Kendell Louther
    Kendell Louther May 21, 2011
    kendelllouther@att.net
  • Panasonic Master
  • 2,098 Answers
May I know your email add, I will send to you the copy on how to set-up your unit.
Jdvillanueva
Posted on May 21, 2011
  • 3 more comments
  • Jdvillanueva
    Jdvillanueva May 21, 2011
    Thanks for the response, I've already sent the copy to the email add you've provided. Hope It will help you. Thanks for using Fixya.
  • paulkim1125 Jun 10, 2011
    could u send it to me also paulkim1125@yahoo.com
  • Tylerk Aug 16, 2011
    Could you send me that email as well to me please. My subs will only work if I have just RCA plugged in.
  • elvin Sep 23, 2012
    hey i hooked it up fine i just what to see if you did something i didn't do email me qmoney03@gmail.com
    hey i hooked minds up but i want to see if you did anything different from what i did email me qmoney03@gmail.com thanks
Use the pre out rca lines not the av lines (these are for connecting audio video not amplifiers
Posted on Sep 24, 2011
Installing a new stereo. I am trying to install a ''JVC KD-R210'' in my wifes 1985 BMW 535i, replacing a Sony CDX-R79 and in the trunk is a Pioneer 12 disc cd changer that was hooked up to the system. This...
There is a line level converter that would need to be purchased to that you can get the front speakers to work with the amplifier. The stereo already has rca jacks for the rear speakers. You can connect these straight to the amplifier for it to work. Bes sure that you use the blue wire to connect to the remote turn on for the amplifiers. Once you get the line level converter you will connect the wires and connect the converter using the RCA jacks. The question would be how was the 12 disc changer connected to the system. Would need more information on the changer in order to help with that component.
Mar 13, 2010 | JVC KD-S550 CD Player
How many rca jacks does it have can u hook to amps up to it
it has 1 audio output. (2 rca's one for left and one for right.)
Depending on how you plan to set up your system, you can pretty much hook up as many amps as you want.
If you are planning to run an amp to your speakers, you can wire it right into the wiring harness. If you are planning to run more then one amp, strapped or bridged etc, you just use a splitter or the pass through if the amp has it.
you only need one set of RCA's to hook up sub amps. however if you are amping the speakers for front and rear, then you wire it right into the harness if the head unit doesn't have separate rcs's for front and rear left and right. RCA's just make it easier but its still possible with out them.
Dec 15, 2009 | Pioneer DEH-1800 CD Player
I just need to know if the 2 channels from the amp go to the front or rear speaker location on the stereo and if they go to the rear do I hook up the rear speakers directly to the amp and the fronts to the...
The only thing that hooks to the stereo are a remote cable should be labeles on the amp. and the rca cables (red and whites) the different channels go to different sets of speakers.right to right left to left. make sure your amp is grounded well or you'll throw the fuse. Hope this helps if you have questions contact me.
Mar 08, 2009 | Sony NTX-2135 DHD 2 Channel Car Amplifier...
Front Speakers Not Working
Hi, as a retired installer maybe i can suggest a better configuration. I would run your front speakers in series with your rear mids in low level. Your sound will be alot cleaner. Hppe that helps.
Aug 26, 2017 | Kenwood KDC-MP332 CD Player
I hooked up a 4 ch alpine amp MRP-F600. The back speakers play nice but the front speakers play very low. What could be the Problem?
1)When you connected the amp to the head unit, did you run two pairs of RCA cables for front and rear reference or did you only run one set of RCA cables from the rear out to the amp?  2)If that's not the case and you did ran two sets, on your amp, swop the rear and front RCA cables. If the rears go quiet and the fronts are loud you now know the issue is either in the cables or how the head unit is set up. If the fronts are still quiet, check your Amp's gain, frequency and filter setter settings (if available). If those settings don't change anything you may have a faulty amp. 3)Check speaker connections, seems trivial, but you never know.
Message me back if nothing works and/or you get stuck.
Ciza
Nov 04, 2008 | Alpine Car Audio & Video
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Car amplifers,,,,kicker amp's RCA jacks!
You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
-Andrew Hawkins
Mar 28, 2008 | Audio Players & Recorders
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
LED lights up but! ???
Sounds like there is a problem with the amp. Try switching the inputs around for that output on the amp. If that does not help, Yes I would have to say that there is a problem with the amp output circuit.
Nov 06, 2007 | Infinity BASSLINK Car Subwoofer
Subwoofer instalation
Even if your JVC doesn't have outputs for a subwoofer you can hook it up with the a speaker wire to RCA converter. You just spice your rear speaker wires to this device then connect RCA's to your amp. I've used them before... works great. http://cgi.ebay.com/ebaymotors/Speaker-to-RCA-Line-Level-Converter-Adjustable-High-Low_W0QQitemZ130143832174QQihZ003QQcategoryZ38636QQcmdZViewItem
Aug 20, 2007 | JVC Arsenal KD-AR560 CD Player
Panasonic CQ-VD7003U Car DVD Player Logo
193 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
