Question about Health & Beauty
How do i attach vacuum cleaner belt? - Health & Beauty
  • 13 Answers
Awdtthtthfghh
Posted on May 21, 2011
I need a belt for a shark model #v131optn power pet upright bagless vacuum
Mark, Google search for a near by vacuum shop and stop in and get a belt or google search your make and model, Belt. Check the attached links for replacement belt, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.sharkclean.com/parts/0/all/484/replacement-belts-2
Vacuum Cleaner Belts Walmart com
Vacuum Cleaner Belts at Ace Hardware
Jul 14, 2016 | Shark Vacuums
How to put on attachment hose
Here is a walkthrough on that with pictures:
Vacuuming Bare Floor with Kirby vacuum
You will need to take off the nozzle to attach the hose.
Install Kirby belt and nozzle
800-775-6586
GoodVac com
Dec 05, 2014 | Kirby Vacuums
Beater bar belt install
  • 1
    Unplug the vacuum cleaner and turn it upside down, flat on the floor, with the roller brush facing up.
  • 2
    Remove the the bottom cover plate from the vacuum by prying it off gently with a screwdriver blade. Set aside the cover plate.
  • 3
    If the old belt is broke, remove it by pulling the belt from underneath the roller bush. If the belt is not broken but simply worn out, and is still attached, cut it off with scissors.
  • 4
    Remove the roller brush by lifting both ends from the grooved slots in the housing of the vacuum cleaner.
  • 5
    Cut away hair, thread, string and other debris wound around the roller, using the scissors. Tangles on the roller brush are a common reason for belt wear and breakdowns due to the added weight and stress on the roller brush.
  • 6
    Slip the replacement belt over the roller brush and seat the belt in the groove in the center of the roller.
  • 7
    Slide the roller brush back into the grooved mounts on either side of the housing and snap into place.
  • 8
    Pull back on the new belt and slip the loop over the pulley attached to the vacuum motor.
  • 9
    Replace the bottom cover by snapping it back on the housing until it clicks into place.
  • Feb 16, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
    Can not attach top back to bottom
    Water pump on vacuum? steam cleaner / carpet cleaner? You have gotten something out of alignment. Check seal and make sure to have everything else in place before trying to screw back together
    Mar 07, 2010 | Bissell Vacuums
    My vacuum cleaner belt keeps burning up as soon as
    CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
    Nov 03, 2009 | Bissell 6594 PowerForce Bagless Upright...
    How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
    Greetings,
    Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
    Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
    How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
    Thanks for watching!
    Chris J.
    Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
    1800 vacuum cleaner belt replacement
    Generic problem for all Vacuums
    How do you get into the belt to replace it?
    Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
    http://www.dooyoo.co.uk/vacuum-cleaner/typhoon-1800-upright-vacuum-cleaner/1021772/
    Apr 07, 2008 | Vacuums
    Health & Beauty Logo
    21 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
