Question about Pentax Espio 738S 35mm Point and Shoot Camera
Pentax espio 738g
When i turn on my camera the zoom lens zooms out then zooms back in and u3 flashes in the display and camera wont take pictures
  • Anonymous Nov 06, 2008
    Just got a new battery for my 738G, Used for 2 days, and put in new roll of film but now when camera is turned on, out comes the lens and then u3 flashes. when it shuts down or automatically turns off, there is a click noise like a shutter click.
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: zoom lens not retracting
May be a bit of grit gas got in. Do not try to manually manipulate it- this will wreck the motor drive. A Vacuum clean suck way have some affect. Certainly contact Pentax Tech Support Team .
Posted on Jul 02, 2007
  • 185 Answers
SOURCE: Pentax espio 140
subaru662,
can you see the lens in the finder move when you zoom out? if not ,the finder lens is stuck.
if it does move when zooming, see if you have a diopter adjustment wheel or sliding knob near the front lens of the finder. if so adjust the lens to your eye.
Posted on Dec 09, 2008
  • 47 Answers
SOURCE: WHERE CAN I FIND BASIC INSTRUCTIONS ON HOW TO USE
You can download the manual from here http://www.pentaximaging.com/support/manuals-and-literature/
Please note that P3N = P30N
Hope this helps.
Thanks,
Kanu
Posted on Sep 09, 2009
  • 571 Answers
SOURCE: I have a Pentax IQZoom 160 and it has error code
If the 'U' disappears when the zoom lever is moved your camera is ready to use. It may be defective if it comes up often.
(IQZoom 160 manual p.49)
Posted on Jan 11, 2010
ftw1952
  • 10319 Answers
SOURCE: pentax camera espio 738g zoom
The camera has a faulty capacitor inside the circuit board. Having it repaired generally cost more than purchasing a replacement camera. Capacitors store the power needed to operate motor drives when needed. If they get a hairline crack on the outer shell they will lose there ability to operate correctly such as yours is doing
Posted on Jan 02, 2011
Need to find manual for Pentax Espio 120 Mi
The Espio 120mi was called the IQ-Zoom 120mi in some parts of the world. You may download a copy of the IQ-Zoom 120mi manual here.
Apr 04, 2012 | Pentax Photography
I was given a 35mm pentax espio 70 zoom camera recently but I have no instruction leaflet with it. Is it possible still to get one.
Most documentation is available online. Use the search engine of your choosing to look for:
Camera manufacturer + model + manual
I believe you can find it here:
Feb 28, 2011 | Pentax Espio 738S 35mm Point and Shoot...
U7 error code when Pentax Espio 200 camera switched on. What does it mean? Can I rewind and remove film to develop?
Its actually a technician code which means that your Zoom system has malfunctioned. If you want to remove the film then you can simply click the reset button and then remove the film. If you want to get it repaired then it would be better if you throw it and look for a new SLR Camera
Oct 22, 2010 | Pentax Espio 200 35mm Film Camera
I have a Pentax IQZoom 160 and it has error code U3 when I turn it on. The flash and zoom try to deploy several times but only the flash comes out.
Dec 04, 2009 | Pentax IQZoom 160 Date 35mm Point and...
AV flashing in LCD of camera whn zoom attached
I found on some lenses you need to go into the menu , select settings and change av appurature setting to 2 instead of 1 .
Feb 20, 2009 | Pentax *ist DL Digital Camera
AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Pentax espio 140
subaru662,
Jun 28, 2008 | Pentax Espio 140V 35mm Point and Shoot...
A Pentax Espio 135M Multi AF Auto Focus 35mm Compact Camera with a SMC Pentax 38mm to 135mm Zoom Len
I sounds like your shutter is stinking dont remove or losen the screws there are manuals on the web. find out what type a camera it is then go to the retail on the web they should have support or manuals for you
Apr 06, 2008 | Cameras
Pentax optio m20 .. on-off immdly
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Zoom lens not retracting
Jul 02, 2007 | Pentax IQZoom 140M 35mm Point and Shoot...
Pentax Espio 738S 35mm Point and Shoot Camera Logo
145 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
halotheracer
halotheracer
Are you a Pentax Camera Expert? Answer questions, earn points and help others
