Question about GE Monogram Side by Side Refrigerator
The freezer temperature varies over periods of days/ weeks from -19 to -6 degrees regardless of how often the door is opened or closed. I have pulled it out from it's surrounding cupboards to improve airflow but no difference
    Sergeant:
    Champion:
  • 257 Answers
I just recently had that problem with a monogram, it turned out to be the temp control unit it's inside the refrigerator. It's control board gets a little corded from the moisture. You can unscrew it pretty easy, 2 screws and examine the board. If you see corrosion or burns on the solder points Just order a new one.
Posted on May 21, 2011
After loading a few new food, temperature is getting up from -19 to -10 and red AL sign. Temperature get down one degree(-11,-12,..) every day. what is the problem? it seems freezer is tired or weak.
Check the door for perfect closure. sometimes the new "load" of food causes the door to stay slightly open. And check the seal for any imperfections that would allow air to get into the freezer. Make sure the coils are clean. I have a similar problem with the refrigerator door and must push it closed whereas, it used to close by itself.
Jul 06, 2015 | Refrigerators
Temperature issues in GE Profile Refrigerator Freezer, what to do?
Sounds like an inefficient compressor or possible overload/relay issue
Jul 25, 2013 | Maytag MZD2768G Side by Side Refrigerator
Fridge temperature rising - currently at 10 degrees. Internal temperature alarm not being triggered. Freezer not affected. Motor running when door opened/closed.
Although I have never worked on a Zanussi unit, from what you have said it is a classic frost build up in the cooling tubes, which is usually a result of defrost system failure. To verify this you can manually defrost your unit. If the problem goes away, then you need to troubleshoot your defrost circuit, because it will be back in days or weeks.
Sep 14, 2011 | Zanussi ZX99 / 5 Bottom Freezer...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Freezer & fridge warms up on average every 6-8 weeks. Remedy turn off and leave 24 plus hours with doors open. On turning on the fridge and freezer cool down again to operating temperature....
Good day,
That's too long a period, for a normal. defrost system failure.
You'll have to wait until it quits, then remove the rear panel and look for ice (not frost) building up somewhere in the freezer compartment.
I have solved similar problems on this model, by replacing the defrost thermostat with a GE 60 degree thermostat, and a WR9X330 GE 6 hour defrost timer to get this model to defrost completely.
It's also possible that the refrigerant charge is slightly low, causing the defrost thermostat not to reach a cold enough temperature to perform a good defrost cycle. (building ice over a long period of time).
Make sure Freon 12 was used when replacing the compressor.
Some substitutes caused the evaporator coil to act as if it was
slightly low on charge.
Nov 08, 2009 | Westinghouse Refrigerators
New upright kenmore freezer temp varies +/- 10 degrees
Over what period of time did this variation occur?
The freezer should have an automatic defrost cycle. The temperature will rise while it is going through this cycle.
Oct 18, 2009 | Freezers
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Oct 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Monogram Side by Side Refrigerator Logo
441 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
