Re: Just wanna know what kind of battery (size &/or...
You can use kodak sr44 or v76px
you will need two of it. and you can get any store. if you very cheap, you can shop 99cent store. They sell as a bundle and very cheap
Good Luck...
You normally rewind cameras to remove exposed film. On an XG-A, there is a small button on the base plate (bottom of camera) which releases the sprocket drive and allows you to rewind the film back into the cassette using the "flip out" rewind button (top right, in above picture).
The XG-A requires batteries, not just for the viewfinder, but also for the shutter. It uses two alkaline A-76 (or equivalent) or two silver-oxide EPX-76 (or equivalent).
If you need an owner's manual, you can download a PDF version from http://www.butkus.org/chinon/minolta.htm
I used minoltas for a number of years while going through college, though unfortunately this problem is fairly common- was a few years back but first time it happened to me i took the camera in for repair and if i recall theres a part that just breaks inside (number of years, cant remember the part).
It would have cost me round £60 to repair- bout 6 times the cost of the camera from ebay- I eventually just started buyin a new one from ebay every time the problem cropped up again.
I realise it may not be what you want to hear if your particularly fond of your camera, but the cost of replacing a part may very well be more than the camera is worth. At the moment I have a minolta XG-M sittin on my shelf, hoping to track down some service manuals and see about taking it apart- I'll let you know if i find anything out, even with my fancy digital camera i still miss using the old 35mm.
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
first push in the rewind button on bottom of camera, then turn the rewind knob to the right to rewind any film that's in the camera. then pull up on the rewind knob to open the back cover.
If everything lights in the camera when you test it ,it means the battery is alright,try this trick"Rotate the film advance connection at the bottom of your camera using a nickle (not the battery compartment) the one directly at the bottom of the shutter and should click if there's not you have some bigger problem.Good luck.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
