Question about Xerox XG-71D 17" Flat Panel LCD Monitor
How can open xerox monitor 700p model - Xerox XG-71D 17" Flat Panel LCD Monitor
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
Power supply filter caps will be he first thing to check, look for leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 11, 2010 | KDS K717s 17" LCD Monitor
Cant get mag 700p monitor to work with toshiba satellite
I HAVE DOWNLOADED resident_evil_4_1.10_eur AND WHEN I CLICKED TO INSTALL IT :INSTALLATION DESTINATION NOT FOUND; IS GIVEN AS ERROR. SOLVE MY PROBLEM PLEASE
Oct 30, 2009 | Computers & Internet
How to use this Proview LCD Monitor 17" 700P AS A TV Screen
No. The newer LCDs can do both. But they are a TV to start with the option to hook up a Desktop.
Feb 08, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Mag 17
it is a problem signal cable of the monitor open the monitor test the continuty of 15 pin signal cable
if pin no 13 & 14 (hsync & vsync)are open then change the cable problem will be solved
Oct 25, 2008 | Computers & Internet
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
KDS K717s = Radius-73 Model 700P
Most are snapped at the corners and center of each side.  A plastic ipod pry tool will usually get the process started, and you just work your way around the frame.  Starting at one corner is best.
srich
May 27, 2008 | Gateway FPD2275W LCD Monitor
Proview 700P lcd monitor problem
Your monitor has been enabled as an extended monitor, not a clone.
Easy way to see is open a window, grab it and drag it to the other monitor (drag it right, not left). Just remember even if you have the external monitor on your left side, it is really on the right side according to the computer.
Check the display properties for a clone option if you want both to show the same thing.
Hope that helps a little.
Apr 09, 2008 | Computers & Internet
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
Xerox XG-71D 17" Flat Panel LCD Monitor Logo
262 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
