Crt monitor gives only yellow colour - Computers & Internet
    Novelist:
  • 100 Answers
Hi this is due to some internal fault like ur capacitor might have burnt or due to failure of picture tube i recommend u to show ur monitor to a monitor or T.V repair shop rather than repairing yourself because it's hazardous so take ur monitor to some repair shop and also check ur warranty and get it repaired. was this helpful to u if yes please do rate my solution.
with warm regards -bonefirediv
Posted on May 21, 2011
My monitor is not displaying colours.... its only showing bit of blue and yellow colour.... please give me solution.....
CRT monitors can fade over time. try resetting factory settings and degaussing, if you have that option. If not, you need a new monitor. Buy an lcd.
Feb 18, 2011 | HP mx705 17" CRT Monitor
Yellowish screen
On a CRT, "yellow" is a mixture of all 3 "primary" colours.
So, if you are expecting some other colour, then one of the 3 "guns" that are emitting one of the primary colours is NOT working correctly.
For less than $100, you can purchase a new, 19-inch (not 17-inch) LCD (not CRT) monitor.
This is less expensive than taking the CRT to a TV/video store for trouble-shooting and repair.
Jan 07, 2011 | Mag Innovision InnoVision 786 PF 17" CRT...
Hi my monitors screen becomes yellowish.all colour effected y dis
Do you have a CRT monitor?
Have you tried to adjust the color on the monitor?
How is it connected to your computer?
It sound like one of the guns on you monitor died. But there is some testing you should do first.
If it is a CRT monitor and it is connect your computer properly. First thing to do would be to replace the cable and or try a different monitor that you know works.
To confirm try adjusting the color. If that does not work, if it more purplish it is the green gun, if it is orangish it is the Blue gun. That would be cause by a failed gun or driver.
If the gun is gone it is best to get a new one. It will save you money in the long run.
Thank you...
Jan 27, 2009 | Samsung 793S 17" CRT Monitor
CRT monitor's background colour is changed to dull yellow colour
hello,
i think this problem accure due to chage of CRT CATHODE. if you are not a hardware engineer then check it from hardware engineer. any crt monotor have 3 RGB Cathode to release electron on screen. the electron comes shodow mask and create a pixel on the screen the pixel make a picture. The RGB color make the perfect picture. if your picture is dull then i think that happen due to less negative chage of Cathode or any Crt base Bios ic is failior. so you have to checked it from hardware engineer.
ok
bye
Oct 22, 2008 | Samsung 21" FLAT CRT COLOR MONITOR
Monitor problem- colour changes to white appearance to yellow appearance
COLOUR MONITER BASE COLOUR IC SOLDING AND BASE SOLDING OR CHEAK DATA CABLE
Mar 18, 2007 | SAMTRON 55V 15" CRT Monitor
The monitor hjas lost its original colour,It potrays images that are a bit red and yellow.Its a Compaq V570
It's probably not a matter for adjustment, it's probably in need of electrical troubleshooting to find and replace defective components. It may be the CRT itself. One way they often fail is to show or lose one particular color more than another. These days a common 15" CRT monitor is probably not economical to repair by a brick-and-mortar service shop.
Jan 06, 2007 | Compaq V 570 15 in.CRT Conventional...
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
