Question about Rinnai Heating & Cooling
My Rinnai Titan MkII is not staying ignited after it is turned on. It may stay on for a few seconds then goes out, please help
tbugger
  • 232 Answers
SOURCE: torpedo heater ignites and then goes out reignites, goes out, etc.
We need to know more. Is this a kerosene or a propane fired heater?
Posted on Oct 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: Heater on,off,on,off,on,off.......
That is a bad wall thermostat.
Posted on Feb 09, 2009
SOURCE: Rinnai burner goes out when ignition button is released
The thermocouple [s] require replacement, or in my experience try servicing the unit first. There is an injector for the main pilot and a secondary injector for the flame thrower ignition. Both of these are prone to blocking due to dust and can be enough to shut the unit down. Although usually this is thermocouple related as you are manually keeping the unit running when you hold down the button, if the tcouple is broken it wont send enough millivolts to hold the magnetic valve open when you release the button.
Cheers
Posted on May 31, 2009
  • 53 Answers
SOURCE: Rinnai Avenger 25 ,brand new ,will light and start, then go out
Temperature sensor is faulty.
Ring them. its under warranty.
Posted on Jul 17, 2009
  • 33 Answers
SOURCE: rinnai energysaver 1000ft wont stay on
Check your gas supply is it turn on ?
Posted on Jan 16, 2010
How do I fix the heater? The igniter will not stay on long. The heater never reaches desired temperature.
Try turning it off and unplugging it for 30 seconds. If that doesnt work, some people I know had to melt ice from their vents with a blow dryer. If not call a technician. Error codes should be in the manual. http://www.rinnai.us/customer-care/manuals-literature
Feb 24, 2015 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a rinnai energy saver 556f our power blew out and it knocked out all our appliances.i am trying to get my rinnai to stay lite but the pilot wont stay on.it goes on for about 3 seconds and then cuts...
Patrick,
Your 556 does not have a pilot light. When you try to start look into the window, you should see an arcing, this is the igniter. With a power outage there is no telling what may have happened. With only limited knowledge of a gas heater you should call a Rinnai service guy.
Good luck,
Tom
Oct 12, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Jun 10, 2009 | Heating & Cooling
How can I stop airbag warning light flashing continuously on my Nissan Tiida
Try this:
5. If “AIR BAG” warning lamp operates as [as I said before], turn ignition switch “OFF” to reset from Diagnosis mode
1. Turn ignition switch “ON”.
2. After “AIR BAG” warning lamp lights for 7 seconds, [i.e. when it stops running solid and starts flashing] turn ignition switch “OFF” within 1 second. [DO NOT SWITCH IT TO LOCK, SWITCH IT TO ACC]
3. Wait more than 3 seconds.
4. Repeat steps 1 to 3 two times. (Perform 3 times in total.)
5. Turn ignition switch “ON”.
SRS is now in Diagnosis mode.
Try it a few times. If you can't get it to work, have someone else try. If you STILL can't get it to work, check your battery voltage. It might be low.
In diagnosis mode, you're going to hope the light flashes slowly. 2 seconds off, 3 seconds on, and repeats. If your light does this, this means that the computer detected a previous error that hasn't been erased. This is good.
to User mode and to erase the memory of the malfunction.
6. Turn ignition switch “ON”. “AIR BAG” warning lamp operates in
User mode. [it should stay on for 7 seconds, then go off, like normal.]
May 17, 2009 | 2006 Nissan Titan
Rinnai water heater continually running
the rinnai comes on when water starts flowing through the unit.
Apr 08, 2008 | Heating & Cooling
Heating & Cooling Logo
268 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
