Question about Sony Cyber-shot DSC-W55 Digital Camera
Whenever i turn my camera on, the lens goes in outand then it goes in again. And it does this a number of times and at the end it turns off. I would appreciate if someone can give me an advice what to fix this problem.
    Sergeant:
    Champion:
  • 214 Answers
Your camera has lens unit defective. Most of case it is sand or dusty cause the problem in the shutter unit and focus and zoom unit...In local repair shop would charge you about $45 to $65. (Part 40, labor 25) good luck with you!
Posted on May 21, 2011
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
When I turn the camera on, the lens come in and
its a problem of your lens guide pin. thats damaged & you face that problem. Just replaced that. Thanks
Mar 27, 2010 | Cameras
It turn the power on and on again and nothing happens
This is a common problem for all Sony Cybershot digital cameras. It is saying the error "Access" because whenever you turn it on, the camera finds it hard to retract and open out the lens. Chances are, there is some sand or maybe dust or dirt of These are few things you can do.
You can blow a compressed air on the camera's lens to try to take off the dirt or granule of sand stuck within the lens. Also, you can try to hold the camera from your right hand with the lens facing the ground and hit the camera's base on your left palm. Do this several times.
Let me know if this helped you. Goodluck!
Sep 16, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Lens goes in and out four times then ask to turn power off and on
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
1. Touch the HOME and select the SETTINGS menu in the Camera.
2. Now, please select the MAIN settings menu.
3. Then select the INITIALIZE option under the MAIN Settings 1 menu.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Option 3:
If the issue still persists then Service may requires to resolve it.
Aug 26, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
How do I fix my camera it goes in and out when I turn it on.
DON'T DO THAT!
This is not a joke........
Use a can of compressed air and blow around the lens while it is extended. Take a relatively firm approach with this problem slap the camera into your palm two or three times.
Not lens down in this case, but using the side or rear of the camera to make contact with your palm
Make sure you have the camera cord around your wrist so as not to lose it across the room.
Do this several times and turn it on and off till the message of tuen ona nd off no longer shows(if it ever did) and the lens retracts and works correctly. The compressed air will help remove any accumulated dust that is jamming the lens.
This is a sony tech fix and not a joke, they charge you $90 to do this and this fault is not uncommon in many of these small cameras
dust and dirt get taken into the lens bay ad eventually cause it to stick. Hence the use of comptressed air with the brutal ap
Jul 31, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My camera says "Turn the power off and on again"
there is a problem with the lens already and it might need replacement. chances are the price of a lens is almost equivalent to a new camera.. just buy a new one.
Aug 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Can't take new pictures!
 Delete some images then try
Still in trouble?
Come back
Oct 16, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Turns on but that's all
Oh yes the Sony Click When the camera powers up it must run a duty cycle to check that all circuits and the lenses are functioning properly. What you are hearing is most likely the gear assembly on the lens is out of time. one gear reaches its limit the motor doesn't know because another component is not is the proper orientation and on gear clicks over another. Never reaching the end The software does not get the information that everything is okay and does not allow the camera to function. Suggest professional Repair.
Aug 02, 2006 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
