Hi there and thanks for your visit, I’d love to offer you a quick safe soulituin however “Sony” the manufacture does not seem to support this product anymore and is about the only place I feel safe to point you. Anytime you obtain a file from an unknown untrusted source you run the risk of installing malicious software/files. So this http://bladeandsoul.mobi/sony-dcra-c171-19/. Is a link I found after a quick google search but please be cautious with your downloading. As always if you have more questions just ask
Many errors in Windows are caused by corrupt files. Those files could have become corrupt because of errors on your hard drive. The Check Disk tool checks for errors and attempts to fix any it finds.
Warning: Use Check Disk at your own risk. On rare occasions I've experienced problems when using check disk in Windows Vista. Here are a few things to watch out for:
If you run check disk and your computer has to be restarted to scan your computer and your computer hangs at a black screen when it boots up, do the following:
Turn the computer off and back on and immediately start pressing F8 on your keyboard repeatedly. A black screen with different boot options will appear. Select to use the Last known good configuration (advanced) boot option.
Never stop check disk once it has started. It could take hours to days to scan your hard drive depending on its size.
How-to Use Check Disk
Using the Graphical User Interface (GUI)
Open the Start Menu and click Computer.
Right-click the drive you want to perform a check disk on and select Properties.
Click the Tools tab in the drive Properties window.
Click Check Now under error checking.
To perform a complete check of your hard drive for errors check off both options in the check disk window that pops up.
Click the Start button to start the process.
If you are trying to check a hard drive that has open files you'll get a message similar to the one shown below.
Click Schedule disk check. Disk check can't check a hard drive that has open files. Your computer will reboot and check the disk before Windows Vista boots up. If you want to cancel the scheduled disk check for any reason, check out this guide.
Using the Command Line Interface
Check Disk can also be run using the command line (DOS) prompt.
Open the command prompt with administrative privileges by typing cmd in the search box in the Start Menu and right-click cmd.exe in the search results and then select Run as Administrator.
Type chkdsk followed by one or a combination of switches listed below in the command prompt.
If you run the check disk (chkdsk) command from the command prompt by typing just chkdsk check disk will run in read only mode. All it does is check for errors. It will not fix any errors it finds unless told to do so. This is done by adding switches when typing chkdsk in the command prompt.
A switch looks something like chkdsk /F. Notice the switch /F after the chkdsk command.
Below is a list of most of the switches used with the check disk command. You can use one or a combination of switches with the check disk command.
D: If you want check disk to scan a drive other than the C: drive, add the drive letter after chkdsk to tell it to scan that drive. If the drive is called X: on your computer it would look like chkdsk X:.
/F: The /F switch is the most common of the chkdsk switches. It tells chkdsk to fix any errors it finds. Chkdsk can't fix errors on a disk that has open files. If chkdsk asks you if you want to check the drive next time Windows Vista boots or dismount the drive choose to check the drive next time Windows Vista boots. Never choose to dismount the drive. That option should only be used by a professional.
/R: The /R switch tells chkdsk to attempt to recover any bad sectors of the hard drive if any are found. A bad sector is a spot on the hard drive that can't hold saved data anymore.
/I: The /I switch tells chkdsk to perform a less detailed but faster disk check.
/C: The /C switch tells chkdsk to skip the checking of cycles within a folder structure which reduces the scan time. Don't ask me what this means.
An example of an exhaustive disk check using the command line interface is:
chkdsk D: /F /R
The check disk command shown above will fix any errors it finds and also attempt to recover bad sectors of the D: drive if any are found.
If all else fails, try 3rd party tool SpinRite.
For a New Hard Disk Recovery with the Sony Recovery DVD's, do a complete restore, and leave the SKIP button selected on the last screen when asked if you want to recover the C: Drive.
Sony are a bit wierd the way they work this step.
Try that anyway and failing this try entering the bios at boot up and making sure your time and date are right and try again.
If you are getting the corrupted drive message this means that you have corrupted data on the hard drive or there is something wrong with the hard drive. If you have tried the built in repair options and they do not work then you will need to format the hard drive with an externally with a computer. The link below will help you do this.
HI, you hard disk drive is failing at this point. you will need to send this unit in for this repair. Sony will need to replace the hard disk. is has failed.
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press
ENTER and switch the printer OFF. Remove the Hard Disk Drive (if
installed) and make sure that the EIO card is installed correctly by
pushing it firmly inwards and checking that the two installation screws
are completely tightened. Switch the printer ON again. If this error code continues to appear then replace the EIO card.
2.)If
this Error Code disappeared after removing the Hard Disk Drive, then
switch the Printer OFF and reinstall the Hard Disk Drive, making sure
that the two installation screws are completely tightened. Switch the
Printer ON again. If this Error Code reappears, then the Hard Disk
Drive could be faulty. Replace the Hard Disk Drive.
3.)If
this system error continues to appear after replacing the EIO card or
the Hard Disk Drive, then replace the Electronics Module...
System Error 04CXX Try the following Steps to resolved an eror:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty. Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
