Question about Toshiba Satellite C655-S5068 Notebook
Hi my laptop has a problem it is a Toshiba C655 S5128 Satellite -- it froze when i opened a folder to play music, so I decided to power it off and restart it but it shows a black screen without any message until i restart it again it shows a message that i should choose an operating system to start.
    Sergeant:
    Habit-Forming:
  • 200 Answers
PLS REMOVE THE POWER CORD AND THE BATTERY FROM YOUR LAPTOP AND WAIT FOR 5 MINS THEN RE-INSERT THEM AND ON IT . SHOULD WORK
. PLS REPLY OR COMMENT. THANKS
Posted on May 21, 2011
I have a Toshiba laptop model# C655-S5501 with a bad keyboard (Gator Aid!). I can't find an exact model # match through Amazon. Will the "Eathtek NEW Keyboard For TOSHIBA SATELLITE C655-S5128 C655
Check eBay. I've been working on computers for years and order ALL of my replacement keyboards through eBay. I just found 9 of them after entering your model number; about $16 with free shipping. Sarawill82 hit the nail on the head for the replacement; you tube is your friend if you're doing it yourself. If it doesn't have your exact laptop, look at other videos. It will give you an idea what you need to look for to replace the keyboard.
It beats paying a computer store a $45+ bench fee, and it will only take you about 15 minutes as a novice.
Don't try to clean it; you could cause more extensive damage than just replacing the keyboard.
Jan 16, 2015 | Toshiba Replacement Keyboard
Power port not working on toshiba c655
You had better replace your laptop charger. Even if you go to repair it, it will cost you the same price of getting a new charger. So it is wise to purchase a new one. Here are two for your reference:
$9.99 for Replacement Toshiba Satellite C655 AC Adapter 65Watt 19V 3.42A
$12.90 for Replacement Toshiba Satellite C655 AC Adapter 75Watt 19V 3.95A
Nov 03, 2012 | Computers & Internet
Z,/,?,and all four directional keys stopped working on my toshiba satillite c655-5128
The keyboard will more than likely need to be replaced, there are no user servicable parts. Go to www.ebay.com type make and model of laptop, refine search to keyboard.
Aug 31, 2012 | Toshiba Satellite C655-S5140 Notebook
Toshiba firewall not working
1 Click the "Start" button and then go to the "Control Panel" icon.
  • 2 Click on the "Security" icon and then click on the "Windows Firewall" icon.
  • 3 Click on the "Off" button.
    Parts Of BMW
  • 4 Click the "OK" button to turn off the firewall.
  • 5 Make your call.
  • Jun 12, 2012 | Toshiba Satellite C655-S5128 Laptop
    Toshiba satellite c655 hinge replace
    If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
    1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
    2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
    3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
    4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
    5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
    6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
    7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
    Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
    How do I raise the volume on C655-S5128/intelco?
    Press Fn+F7 and just keep tapping F7 to increase it more. To lower down the volume please use F6 instead.
    Thank you!
    Jul 10, 2011 | Toshiba Computers & Internet
    Do my laptop have a mic toshiba satellite c655
    There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
    Feb 16, 2011 | Toshiba (P000257700) Microphone
    How do I replace the keyboard?
    next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
    Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
    Keyboard inoperative
    press and hold fn and press f11.it sounds like you activated the sticky keys
    Nov 22, 2007 | Toshiba Satellite A135 Notebook
    Toshiba Satellite C655-S5068 Notebook Logo
    219 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
