Question about Gateway GX7022E (RBGX7022E) PC Desktop
Can not connect the Gateway GX7022E (RBGX7022E) PC Desktop. It says is connected but when you try to open explorer, it does not be able to connect but my other computer when i try they connect good
    Master:
  • 409 Answers
Are they both connected with a 'wire' Ethernet cable, or are one or both of them using Wireless for their Network connection ?
Also ensure that IE is not set to 'work offline' (click File and note if 'work offline' has a check next to it. if it does, then un-check it.)
Posted on Oct 30, 2014
5 Suggested Answers
  • 10 Answers
SOURCE: How Do I Open The PC to Add Memory
Hi Elmiragez
In order to open the E-4000 chassis, you have to press a button that blends in with the rest of the system's front panel. Once open you will be able to get to memory and all. The button does blend in with the system's front panel.
Hope this is your answers your question an solves it?
Posted on Jun 23, 2008
Hargak
  • 63 Answers
SOURCE: I have a Gateway Desktop
You may need to put your model number in gateways website and download the drivers to a thumb drive or burn to a cd before attempting this.
The fastest resolution to this problem is to take a respective windows disk (make sure you check your key on the side of the tower and see if it says xp home or xp professional) whichever you have get a windows disk the same as this and boot from the windows disk first it will ask you if you want to boot from cd press any key do so. then it will load drivers. it will then ask you if you want to load the recovery console or if you want to install windows, press what key it says for installing windows. it will then check for previous versions of windows xp on the computer. eventually it will pop-up with a license agreement, press F8 to accept. then if you used the appropriate disc (XP or PRO) it will then ask if you want to repair the previous installation of windows. press r for repair. it will then begin the repair copying files then rebooting. do not remove the disc and do not hit a key when it asks if you want to boot from the cd rom at this point. it will do it's thing for about 2-5 minutes. at this point it will ask for a license key which you will type in from your key located on the outside of the case. hit enter it will continue, if it has a question about network settings tell it to use defualt. if any other pop-ups appear between now and reboot cancel the pop-up. it will reboot and again do not boot from the cd let it time out, and done you will be in windows xp. install all drivers needed and run automatic updates if auto updates do not work google: automatic update repair batch file. there are a few out there that will auto clear the cache for updates. after running it for a while and a couple more reboots then updates will function properly.
Posted on Jul 02, 2008
TampaNative
  • 778 Answers
SOURCE: My Gateway 507GR PC desktop will not connect to internet
Turn off (unplug if necessary) your modem, router, and PC. Then power on the modem, wait a minute and then power on the router, then power on your PC, this should solve your issue if you have service.
Posted on Sep 08, 2009
  • 66 Answers
SOURCE: I have a gateway gx7022e
At power on / power up, look for the key during the bootup (black screen with white text), that allows you to enter SETUP. If none designated such as F1, F2 F10 etc, then quickly click the delete button a few times and that may get you into setup. You may have to turn off the computer if you miss that window of time if it rfequires pressing the delete button a few times. Keep an eye out for the Enter Setup key though. To turn off the computer press and hold the power button 'till is shuts down and resart the process until you get to the setup screen in bios. In setup bios environment, look for set factory defaults and then save and restart. That may solve the issue of the lockup.
Posted on Jan 10, 2011
Sound card
thomas, arre WINDOWS AUDIO ON ? .
if not go to services and RESTART WINDOWS AUDIO.
May 18, 2013 | Gateway GX7022E (RBGX7022E) PC Desktop
How do i know if my video card is bad?
Ensure that the drivers are correct and installed properly. Use a cable and monitor that have been tested as working. If you have another video card, and it works in the same machine, then your card is probably bad. You might also try the card in another machine.
Nov 12, 2012 | Gateway GX7022E (RBGX7022E) PC Desktop
Is it possible to make it wireless
To make this PC wireless capable, you would have to install a wireless network interface card, also known as a wi-fi card or wireless adapter. There are also USB wireless adapters, so you wouldn't have to open your case and install a card. For more information, here is a link to the Wikipedia article: http://en.wikipedia.org/wiki/Wireless_network_interface_controller
Apr 13, 2012 | Gateway GX7022E (RBGX7022E) PC Desktop
I have a gateway gx7022e windows xp computer. When i try to boot it up the white letters pop up then the screen goes to the gateway screen and freezes. Then my num lock comes on but my keyboard wont work....
Jan 10, 2011 | Gateway GX7022E (RBGX7022E) PC Desktop
Gx7022e is there a firmware upgrade for my media reader on my computer so i can read sd hc camera cards?
nope. if it works with other cards but not with SDHC cards you need to buy a card reader, they are very cheap
Sep 30, 2010 | Gateway GX7022E (RBGX7022E) PC Desktop
My computer says i don't have sound card installed or hardware
Try plugging the sound card in a different slot, if this doesn't work the sound card is probably bad.
Jan 12, 2010 | Gateway GX7022E (RBGX7022E) PC Desktop
Overheating
The overheating fan is not controlled by a software, there are three reasons why your fan overheats. First in the hard drive, your fan is not connected properly. Second you need thermal paste to keep the metal part of the fan to stick to the CPU to cool it down. The last thing is that the fan could be dusty and not running as usual.
Sep 08, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
Beeps
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Jul 06, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
GX7022E Gateway computer no power up
*check for the powercord wheather it is good or not
*check the power outlet
*in bios see wheather hardware settings are correct
*open the system then see power switches are connected properly or wheather there is an any loose connection
*check the cpu fan is working properly or cpu is heating and see cpu is placed properly
*keyboard is connected properly
*check jumper settings are proper
Jun 24, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
Gateway GX7022E (RBGX7022E) PC Desktop Logo
100 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
