Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
SOUND ROBLEM - Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
  • Intel Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 21, 2011
Nokia 602 lcd lite solution keypd is working but lcd ite is not working plz solve this roblem
Jul 30, 2013 | Radio Communications
When i am install sound card driver system blue screen
Install the correct manufacturers driver first.
Apr 04, 2017 | Computers & Internet
I have acompaq presario 6000 but when I moved and plugged my speakers bak in al I get is static. I cannot get any sound. I plugged the speakers into another computer and they work just fine so the speakers...
Make sure you are plugged into the small green 3.5mm jack. if there is no sound whatsoever, then it is a failed amplifier. if there is staticky sound then you likely have a failed 3.5mm jack. Try plugging the speakers into a headphone port (if available) or disable to on-board sound device, puchase an add-in 3d soundcard and circumvent the issue.
Oct 01, 2009 | Compaq Computers & Internet
Have 2000 saturn sl1 replace cyl and keys in
try putting the shifter in N and move the pressure off the wheel.
Jun 05, 2009 | 2002 Saturn Sl
Maxtor 3100 will not work on Desktop with Windows XP Home version
actually telephone numbers are not available through this service...perhaps you will consider a premium or chat investment of your resources.
Oct 20, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
My car makes a loud sound when I turn the wheel.
does it make the noise when u turn the wheel all the way? or when u slightly turn it? if so that is the same roblem i have. i doubt its the roters.
Aug 07, 2008 | 1998 Ford Expedition
Net work
what you need to do is check with the network on the phone to the band you are using these phones are tri-band not quad band they will be either 900mhz/1800mhz/1900mhz or 850mhz/1800mhz/1900mhz
Feb 29, 2008 | Nokia 5200 Cellular Phone
No Power
maybe you have a p[roblem with your plug, if you see the orange light then it is charging
Dec 20, 2007 | Canon ES8400V Camcorder
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
136 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
