Sad instrumental music with Chorus Hook - Computers & Internet
  • 47 Answers
Not properly complete download the files
Posted on May 21, 2011
Hooking up two amps together
Yes. There could be big issues depending on how you want to "hook" them together. If you are wanting to simply run them at the same time (play through both at once) you can get a cheap signal splitter from GC or Radioshack and run your bass to the input, then output 1 and 2 to the respective amps. That is your best bet.
Setting up two amps parrallel does not nessesarily add power. That is to say that your 150 and your 350 "hooked" together does not give you 500 watts. In addition, there may be some issues with running a powered signal from the first amp into an input that is not designed for powered signals. Try the splitter or an old fashioned AB box. Safe and a cool trick. You can also use a stereo chorus pedal and let the signal chorus between amps. Makes the bass sound huge! Try it and good luck.
Jun 17, 2013 | Fender Music
All im hearing is the instrumental and background music not the lyrics
u might be connecting the EARPHONES with a microphone, if that so, then don't insert fully - the 3.5mm jack into the player.
partially insert it into the JACKPORT and listen to the music...
Apr 11, 2013 | Polaroid PMP120-4 4GB USB 2.0 MP3 Digital...
Chorus emits a pulsating noise
Sounds to me like low-end gear. You honestly get what you pay for. If it happens to be high-end then you have either bad cables or just a bad effects processor. If you have on-board effects built into the amp, then get better equipment.
Hope this helps.
Aug 31, 2012 | Ibanez IBZ10A 10 WATT ACOUSTIC AMPLIFIER...
Chorus on- no problem- noise free. Chorus off- big problem- massive hum. This item is supposedly "new" (stupid me, I bought from Ebay...)
It sounds like the bypass contacts on the pedal are not working... this may be right in the pedal switch itself. With unit in off position, use an ohmmeter to check continuity between in and out cable tips.
Sep 07, 2011 | Electro-Harmonix Electro Harmonix Neo...
MY MXR STEREO CHORUS LED LIGHT START TO FADE AFTER CONNECT WITH DC BRICK! DOES THIS MEAN MY PEDAL WILL HAVING ANY DEFECT?
I don't know what you mean by "DC Brick"...
The MXR Stereo Chorus unit requires a special 18 Volt power adapter. The common 9 volt pedal power adapters will NOT work with this device. If you have batteries in the unit, when you plug in an incorrect adapter, the unit disconnects from the batteries and the caps discharge so the light will fade.
You will need to use: ECB-004 18-volt AC Adapter Best to use the manufacture's exact device for this one.
Jan 12, 2011 | MXR Stereo Chorus Pedal Guitar
When playing it has a roaring sound and the chorus on and off is loss
Who could even guess what musical instrument you are talking about...
BUT I will say that if it is a device with a chorus setting that uses CCD (charge coupled device delay line), there COULD be a problem with the device. This would be a job for a service shop for the unit.
Jan 15, 2010 | Music
Hi, I have a Marshall 8240. The Reverb output
probably the reverb tank These coils are very thin and tent to break easily
Nov 05, 2009 | Marshall Amplification Marshall MG250DFX...
The proper way of setting up a foot board to my amp and guitar
Run a jack from your guitar to Input R Mono on the pedal.
Run a jack from Output R Mono on the pedal to the input of your amplifier.
There is a switch for guitar or Bass. Put the swich on guitar
You do not need a preamp to use this pedal.
Hope this helps,
Maxx.
Aug 27, 2008 | Boss Music
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
