Question about Intel a19845-003 - PRO/1000 T Server Adapter 64-Bit walt (A19845003) Network Adapter
How to remove intel cooler c33218-003 to CPU in my Computer Desktop
I have a vostro 200 large tower with a g33m02 motherboard. The cpu cooling fan is very loud. (not bearing loud, but it seams to try a lot harder than it needs too for what the computer is doing.) the cpu...
Check your BIOS Settings
CPU Configuration
CPU Internal Thermal Control [Auto]
Hyper Threading Function [Enabled]
Intel(R) SpeedStep(tm) Tech [Auto]
Power>Hardware Monitor
CPU Q-Fan Control [Enable]
CPU Fan Ratio [Auto]
CPU Target Temperature [60degC] (lowest setting available)
or you can replace it with Cooler Master XDream
Sep 20, 2011 | Dell Vostro 200 Desktop Computer
Hi there, A friend has a desktop system that, although it is booting-up and reaching the desktop, it soon shuts itself down. I have carried out RAM diagnostics & all is fine there, does anybody at...
Since the computer comes to desktop, most of the hardware is (more or less) fine. Check the time that the computer stays "power on". If it shuts down after some minutes (more than 4, less than 40, depends on the CPU, cooler etc) it's a matter of temperature. Unplug the desktop from all the peripherals and power source, remove the covers and use an air blower to blow out all the dust from inside the desktop. Take special care at the cpu cooler, the vga cooler (if any) and at the power supply system. After this leave the desktop some minutes to calm down, put the covers back and check the results.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Dec 28, 2010 | Intel Computers & Internet
Car won't start when hot. only starts in morning when cool. is this the icm?
Sounds like the CPU HSF is loose or has stopped
The HSF.. heat sink and fan needs to be running or the motherboard sensors will just shut the computer down.
This board in an intel LGA775 and uses this type of CPU cooler
http://www.aria.co.uk/Products/Components/Fans%2C+Heatsinks%2C+Coolers/CPU+Coolers/?x=12&p_order=price_asc&p=cF9zdHlsZT1kZXRhaWwmcF9wcm9kdWN0c1BlclBhZ2U9Jg==
You can get a new 1 for under £10 and they are not to hard to fit
Jul 10, 2010 | Intel D945GCCR Motherboard
Anyone have any idea what type of cpu cooler?
you could try koolance they make excellent water coolers. i own the 750 myself. if this helps please rate this.
Mar 24, 2010 | Microsoft Systemax SG 1150 Gaming Desktop...
I need a cpu fan what size does it take
It goes by which socket you have. I am an Intel connoisseur so my knowledge ends with Intel PCs.
If your processor is an early Intel Pentium 4, you will want a socket 478 CPU cooler.
If your processor is a late Intel Pentium 4 or Intel Core 2 Duo/Quad (~2ghz+) you will want a socket 775 CPU cooler. Luckily this socket is still in wide use and many can be found locally or online.
If your processor is an Intel Core i7, you will want a socket 1366 cooler.
Just go to a local PC store and ask for an LGA478, LGA775, or LGA1366 CPU heatsink.
Apr 11, 2009 | Gateway GP PC Desktop
Finding a cpu cooler replacement for motherboard with screwholes.
You should be able to purchase a cooler that fits your existing cooler plate.
Replacing a cooler can sometimes be a lot of work. Sometimes you have to remove the motherboard from the case and remove the cooler plate from the underside of the motherboard. Then coolers that use "just the holes" can be used. Or another (different) cooler plate can be installed that may have came with your new cooler. In my experience, the coolers that use "just the holes" (no plate) leave a lot to be desired. Plus, if you're not careful, you can damage the motherboard by applying too much force when installing the fan. If you use a new plate, don't forget to install the insulator between the motherboard and the plate, if it comes with one.
Be careful to protect against unwanted electrostatic discharge. Always touch the metal computer case before touching any parts inside the computer. Also, if you remove the mobo, take careful note of where all the wires go before disassembly.
Feb 13, 2009 | Gateway 838GM (RB838GM) PC Desktop
How to change
Hi
Replacing the heatsink fan on a PC is not a difficult job, but it pays to be thorough, especially with cleaning the top of the CPU die before replacing the fan.
Don't be mean with money when choosing a new cooler either. With CPU coolers you get what you pay for. I personally always use coolers from a company called Zalman.
Ok ..with that out of the way ..the basics are ...remove old cooler..
They are either held on by a sprung clip that fits across the cooler and locates in lugs on the cpu socket surround, or they are held by screws that go through the motherboard.
Clean the top face of the cpu die carefully making sure to use a blunt implement ..... scratches on the machined face will lead to premature failure due to overheating.
If the cooler you buy has a "thermal pad" stuck to the face of the heatsink, then remove this too and clean up the heatsink face. Use good quality thermal paste on the top face of the CPU die, then fit the new cooler. Getting the right amount of thermal paste is a bit of an art .... too much is a bad as too little. The paste is NOT a glue. The paste simply fills in any imperfections on the machined surfaces of the cpu die and the heatsink to aid heat transfer.
Does this sound complicated? It isn't really. The key is not to rush it and make sure the surfaces are completley clean and the thermal paste applied correctly.
Here is a link to one tutorial on fitting cpu coolers that you might find useful:
http://www.jsyte.com/tutorials/replacehsf
Oct 31, 2008 | Intel Socket 478 CPU COLLING FAN & HEAT...
Get solution
I think that you have to buy another one because when win XP installed in your PC it will take very long time to respond your command
Sep 25, 2008 | Intel Pentium II slot 1 233Mhz...
No boot, continuous Beep
I would take the CPU back out. Remove the excess thermal compound, you should only use a very thin layer. Make sure the CPU is oriented and seated properly.
Jun 06, 2008 | ASUS AI Lifestyle P5N32-E SLI...
Heatsink Removal
This is an easy one. :)
I am assuming that you're asking about removing your typical P4 HSF.
Direct from Intel's very own website! :)
http://support.intel.com/support/processors/pentium4/sb/CS-007989.htm#Removal
Good luck and please be careful. *nods*
Cyryl
Nov 04, 2007 | Intel Pentium 4 Socket 478-Pin Cooling Fan...
Computers & Internet Logo
326 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
