Question about Onkyo TX-SR502 Receiver
I have an Onkyo TX-SR803. Recently, I do not have sound for about 5 minutes. The sound is then available for hours. What causes this? How can it be fixed?
  • jfitd May 21, 2011
    Why is there reference to the SR502 in your answer?
    How could there be settings for the headphones if sound is emitted from speakers within 5 minutes?
  • Onkyo Master
  • 11,800 Answers
I'm assuming that you have checked the settings and the speakers are selected as outputs (not the headphones) and they are properly configured- someone might have pushed the wrong button on the remote and change the previous settings.
Most likely it's a bad contact in the power relays . To certify that you will have to open the unit and measure the voltages on them - in and out. If the relays are indeed at fault they will have to be replaced - this is a relatively complicated job that should be left to someone who has at least a basic experience in repairing electronics.
Posted on May 21, 2011
  • Azrael SRL May 21, 2011
    The reference if from where you have posted the question, not from me. If the headphone is activated but not plugged the system should automatically switch to the speakers almost immediately - 5 minutes is almost too much time for that, it indicates that something is wrong either with the settings (the automatic switching might have been disabled) or with the circuit that is supposed to do the sensing and switching = hardware malfunctioning. If it's the latter then the receiver will have to be tested, a job strictly for a well-qualified repairman.
How do I connect a sony BDP-s350 blue ray player to a onkyo tx-sr803 7.1 receiver with the hdmi cable?
Connect HDMI cable from the rear panel of the blu ray player to the DVD/IN digital section, labeled as "HDMI/IN" on the rear panel of the receiver.
Jan 01, 2010 | Onkyo TX-SR803 Receiver
Onkyo TX-SV414Pro. No audio. Displays "Protect"
something is wrong either in one of your speaker connections or in the unit itself unplug for awhile to reset.try it again.make sure all connections are correct and nothing is touching.if that does not work it will be the unit itself
Jun 11, 2009 | Onkyo TX-SR803 Receiver
TX-SR803 with no sound or popping hissing on any input
It is common for a short term power surge to open up the internal fuse in the main power transformer. Without testing some components inside the unit, I really can't say for sure whether or not the unit is worth repair. I would suggest that you invest in a detailed repair estimate at an authorized Onkyo service center.
Keep us posted.
Dan
May 26, 2009 | Onkyo TX-SR803 Receiver
Receiver switches to standby without notice
This receiver is likely to be overheating or has a shorted speaker wire. If the unit is very warm when it shuts down then it is in need of some additional ventilation. Onkyo's tend to run hot so this is critical for proper operation. A speaker wire problem could also cause an issue when the unit detecs a no load situation.
Feb 25, 2009 | Onkyo TX-SR803 Receiver
Onkyo TX-SR805 - surround sound problem
The speaker impedance is not the problem.
Apr 09, 2017 | Onkyo TX-SR803 Receiver
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
Onkyo SR-803 UNPOWERED Subwoofer conectio0n
HI,run speaker cables from "b" speakers out put to speaker in puts on the sub and switch "b" speakers on on the amp.
hope this helps.
CABLE GUY.
Jul 28, 2008 | Onkyo TX-SR803 Receiver
Onkyo tx-sr804 ..problem with the remote
PRESS THE RECIVER BUTTON THIS SHOULD WORK THE AMP AGAIN.
HOPE THIS HELPS.
CABLE GUY.
Mar 26, 2008 | Onkyo TX-SR803 Receiver
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
Onkyo TX-SR502 Receiver Logo
56 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
